Question about Celestion Audio Players & Recorders
Celestion SRC2 manual - Celestion Audio Players & Recorders
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
How do I set up a Celestion S10 Subwoofer...
OK
Voltage is relevant to where you live in the world. America it's 110. Europe mostly 220.
What you're asking is a very deep and complicated question.
I'm attaching a link with some articles.
What I suggest is that you find an upper end audio store and ask a 20 audio head to set up your system for you. Subwoofer Setup and Calibration for Best Bass
Apr 12, 2014 | Celestion S10 Subwoofer
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
Echo Celeste Harmonica Notes Stick then clear what causes this? I have already returned an Echo Celeste because of this problem and received a replacement, but a note on the replacement has just stuck. I...
Try spraying a bit of CRC226 on the reeds. It is available at Home Depot in the electrical dept. It is in a blue spray can... about $2.70. It is a very light silicone water displacer.
May 12, 2010 | Hohner Echo Celeste Harmonica Key of B
Is the celestion truvox 0818mr a good midrange speaker?
there ok but i like RE AUDIOS USAMPS.There some sweet sounding mids.i have 6x9s and 5x7s
Nov 04, 2009 | Celestion Truvox 0818MR Car Speaker
Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
Aug 03, 2008 | Celestion AVF302 Main / Stereo Speaker
Celestion QXa 152 PA speakers
Well, if you can manage to open it and check for a "blown fuse" and change a good one... if it works ... you are lucky. I'll hope and pray that it's only the FUSE.
Jan 02, 2008 | Celestion 1525E Coaxial Car Speaker
131 people viewed this question
Top Celestion Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Robert Rankin
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
