Question about Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
I have a Linksys BEFSR41 Cable/DSL Router and a RCA DCM425 Cable Modem (Provided by ISP) and I have a Intermitant Internet Connection problem. During the day I can connect to the Internet no Problem but at night I can't. The Cable Modem keeps acquiring and dropping the signal every 5 mins or so at night mostly (Sometime it happens during the day) Recently I called my ISP for tech support and they suggested I unhook my router plug my Modem directly into my computer and i seems to work but i want to have my router hooked up and i feel if it worked some of time flawlessly why couldn't it work all the time if there is a solution out there for it I would apprecate it
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Posted on Mar 13, 2009
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My linksys router keeps dropping connectivity to the internet
does your router and your landline phone is in one connection in with a splitter..
does connection failed whenever there's a call?
if so your splitter might be broken
or you must insert your phone line with the splitter, it might be in your connection set up..
or make sure your utp cable is stable and not in exposure area of people or pet where it might be touch or something..
hope this helps...
Jan 13, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Linksys Cable/DSL Router model BEFSR4141
Since you did not include the type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Oct 25, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Oct 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-G WRT54G Router Logo
474 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
