Question about Palm TX Handheld
On/Off swithch works intermittent, all others work
My guess it is a dirty switch. Can I take the 5 star screws out and clean it? Has anyone done that?
Thanks,
Jim
  • 89 Answers
You can take the back off and re-solder the switch which is a common problem in the palm units.
take apart instructions can be found at www.pdaparts.com
Posted on Mar 13, 2009
Goes in reverse when i push start button
The control panel switch membrane is dirty. You take the right side cover off, take the entire control panel off ( 2 philip screws). The take the control panel apart (5 philip screws) wipe off the connections on the pcb and also clean the "buttons" on the reverse side of the membrane switch. it will work, you still need to replace the membrane in the near future. dirty connection was giving false reverse signal. Westco Laminating Service 405-324-6092
Oct 10, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
Why will my vhf radio not respond to on/off switch
Odds are you have a dirty contact. Soft!!!! Touch switches are exactly that. The switchs in a tv remote, microwave oven, calculator or office equipment have this type of swithch. If you find your pushing them harder to activate them, they need cleaned or batteries need replaced. When I worked on copiers (27years) I noticed that only the the slower copiers had keyboard switch problems. I called this the elevator syndrome. You know the more times you push the button the faster the elevator goes? Ultimately this damaged the button resulting in a cracked solider joint . Possibility #2. I have a set of the radios your discribing odds are it's option #2. They force you to hold swithch down until it "boots up" end result cracked solider joint goog luck , brethall610@icloud.com
Sep 28, 2014 | Radio Communications
I have a Kenmore HE2 dryer that was working just fine. My husband stopped it in the middle of it's cycle to check on the clothes. He cleaned the lint trap and put back. When he closed the door and tried to...
you can unplug it for about 30 minutes, but I would venture to guess that the sensor which is located below the lint trap(if you look down the trap you will see to screws) is dirty and need to be cleaned, clean gently as not to break the sensor. Good Luck Tim
Feb 25, 2011 | Kenmore 85871 Electric Dryer
The on off switch in my Franklin Wordmaster only works intermittently. I would like to clean the contact that this makes work but cannot take the device apart. I have removed the 2 screws in the rear but...
take a sharp cutter blade and try to separate the two two from the joint ...u have to put a bit effort as there are plastic locks to hold the two together
Aug 29, 2010 | Franklin Spelling Ace SA-206S
Intermittent wipers don?t work properly, 98 dodge van
Mine was the Body Control Module (BCM). Switched it out (needs to be programmed) and everything was fine.
Sep 14, 2017 | 1998 Dodge Grand Caravan
THE WINDSHIELD WIPER SWITCH INTERMITTENTLY FAILS TO WORK IN MY 2005 GRAND CARAVAN. INTERESTINGLY PUSHING THE WASH BUTTON(EVEN WHEN NO RESPONSE TO THE USUAL CONTROL SWITCH) SUCCESSFULLY ACTIVATES THE WIPERS...
you need to take the two covers around the steering column and the switch there is two-there screws from underneath after that seperate to two covers put some force, then you will see the switch there is one screw or two, pulled out.
Jul 19, 2009 | 2005 Dodge Grand Caravan
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
ERROR message - CD is dirty or not put in the magazine correctly
hi for starters look carefuly if you are putting the CD's in the right side inside the magazine and the magazine itself in its right position take a air spry can and clean the laser eye of the changer while ur at it clean the whole changer from dust and dirt good luck windman
Jan 01, 2006 | Sony CDX-600DSP CD Changer
Palm TX Handheld Logo
48 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
