Question about GE JTP85 Electric Double Oven
Remove GE JTP85 Microwave oven
My question: How to remove the GE JTP85 Microwave oven from the "double" microwave/convection set?. I want to (and know how to) replace the failed Magnetron but I need help on removing the Mircrowave unit from the wall. Thank you very much for your help.
Dinh
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave replacement magnetron
At first I was concerned but then I realized what it was.
Congrats on their sending you the mag!
How did you convince them to do that? Did they make you sign a waiver?
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 28, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
freetek
  • 5568 Answers
SOURCE: Burnt bulb in GE JE1590sc001 convection microwave
You can locate it by looking inside the cavity for an area that is perforated.
If this area is not a panel that can be removed, replacing it may (often) require removing a few sheet metal screws along the rear edge of the unit; rarely is the housing held on with more than that.
With the screws removed, lift up on the rear edge and pull toward the back.
DO NOT LEAVE IT PLUGGED IN!
Also, because there are components that may keep a charge (capacitors) for hours, I would recommend letting it sit unplugged overnight before removing the housing.
The bulb may be either a cylindrical type such as many sewing machines use or a smaller version of a standard bulb.
Neither of which anyone ever has at home, of course.
Any of the large 'home improvement' stores should have these 'made in China' bulbs at an inflated price.
Posted on Jun 03, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
Nov 13, 2013 | KitchenAid Architect Series KEMC308KSS...
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | GE JTP85 Electric Double Oven
MICROWAVE IS NOT HEATING AND MAKES NOISE
heatman101
Mar 13, 2010 | GE JTP85 Electric Double Oven
GE MODEL#JTP85W0W MICROWAVE IS NOT HEATING AND MAKING NOISE
heatman101
Microwave is not heating and making loud noise and smells like burning
heatman101
jkl
Jan 20, 2010 | GE JTP85 Electric Double Oven
MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Nov 19, 2007 | GE JTP85 Electric Double Oven
GE JTP85 Electric Double Oven Logo
120 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
