Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Cannot find code to program sky remote control
The television is toshiba 42rv555db lcd
  • 325 Answers
Please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Posted on Sep 17, 2009
  • 4 Answers
To enter the desired code on your Sky HD Remote:-
  • Press TV
  • Press Select and the Red button until it blinks twice
  • Press TV again
  • Enter 4 digit code(Toshiba is 0156)
  • Press power button.
Posted on Apr 28, 2010
Program toshiba remote RC_3910 to sky remote need code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 04, 2014 | Televison & Video
Have a Toshiba 26A3000R TV have a sky remote v4 anyone know the sky code please? Thanks
Sky don't list a specific code for the 26A3000R, but there are some generic codes for Toshiba TVs with a Rev 4 remote:
0536, 0581, 0063, 0473, 0530, 0746, 0121, 0742, 0173
Try each of the above codes until you find one that works the power and volume functions. If you have no success or you need code entry instructions, please post back and I will try to assist you further.
Regards,
BElectric
Nov 28, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
Toshiba Regza 37RV635D remote control,will not switch on without lots of unplugging etc?
1536. for more info visit:
Program your Sky remote to control your TV Official sky website with latest codes for all tv models with easy steps.
Nov 08, 2010 | Toshiba Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Had sky + h d installed engineer does not no code twf tv
perss interactive on sky remote move down to sky customer service press select move down to program your remote you will need the manufacture and model number of the tv they are found on back of the tv once you have them folow the on screen instructions
hope this helps
Nov 14, 2009 | Sanyo DP26746 26 in. LCD Television
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
534 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
