Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Logicom nova 350 telephone
The phone is working and charged but the bell does not ring on incoming calls
SOURCE: can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Posted on Mar 03, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Posted on Dec 30, 2009
  • 6 Answers
SOURCE: No ring on incoming calls
I found this in statement in a review of Magicjack on Amazon, hope it helps.
The one problem I did encounter was at the beginning when I found that one of my phones wouldn't ring when someone called me. By googling the problem, I found out that this problem is due to the ringer equivalency number (REN) of the phone you are using (google "phone REN" to find out what it is). Most phones have their REN listed at the bottom of the base unit. From my experience, I believe Magicjack will only work for phones that have REN of up to 1.0B (add up all phones in your system to get your total REN. Mine had a corded base with 0.6B REN with 2 more cordless handsets. I figured that made my phone system total to 1.8B REN). Magicjack did ring on a phone that had 0.98B REN. To fix the problem, I bought a multi-handset GE DECT 6.0 (model 28223 Series) which basically has REN 0.0B. Magicjack had no problems ringing with this phone. My phone system was over 3 years old anyway so I didn't mind replacing it.
Posted on Oct 28, 2010
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
I need user instructions for logicom nova 502 telephone as i bought the phones in france and the instructions arein french
  • I'm afraid that since this is a french-sold phone, there is no English manual.
  • Please reply if you have any more questions. Good Luck!
Jul 07, 2011 | Cell Phones
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I have just purchased a Logicom OLEA 350/352/353 Cordless telephone and need a user manual in English
dear All please help me I purchase a phone logicom Olea pop 350
And Olea Classic 352
could you send me the instructions guide in English
Here is my email
rania.sayed@charmaine.com.eg
Nov 01, 2010 | Lands Phones
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
New Idelt phone system not ringing on incoming calls
I had placed the base unit where the telephone line enters our home. When I swapped it to the extension all worked properly
Jan 18, 2009 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
55 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
