Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Very noisy when turned on, then shuts down, Samsung 61 inch
It sounds like a fan running then binding up, but a visual of both fans shows no problem. Even replaced the small one! Just Replaced the bulb, because of previous bad bulb indicators on the front ,but the racket continues until the set shuts itself down in 30 seconds or so. Thanks in advance for any suggestions.
  • Coastal Cuda Nov 20, 2007
    If in fact it is the color wheel and you order the part , can this be done in the home by the owner or does it require a tech to do the install? I have the simular DLP TV HL-R4667W and just got done replacing the projection Lamp myself, it was a pull and plug component. Took me about 3 minutes to change out. Ordered part on line cost$149.99 plus shipping ,but avoided the cost of labor, and taking to shop.
    I called the authorized service shop to check on the color wheel problem ,they said it would take one day to fix and cost approx. $400.00 for part ,labor and tax, with me bringing the TV to the shop.
    Love the TV, but I have not had it 2 years yet and it looks like its going to cost me about $600.00 in repairs so far when I replace the color wheel. HELP. The part on line is $97.00, plus shipping, that means labor is approx. $300.00 WHAT!, HELP.
    President:
  • 3,130 Answers
That certainoy sounds like the color wheel assembly inside of the light engine is bad. The light engine is located here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00674A&search%5Fmodel=HLP4663W Good Luck
Posted on Aug 04, 2007
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
61" samsung DLP 3 years old. Keeps turning off by itself.
Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Overheating of 56 in projection screen, samsung
do you get any blinking lights? if so how many times and how many lights?
Dec 13, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
