Question about Garden
How to change a fuel line on a dolmar ps-401 chainsaw ?
Change fuel line
5 Suggested Answers
SOURCE: parts manual for dolmar chainsaw made in 1987. I beleave it is modle ps7900.
I went to the dealer of the chainsaw and asked for the manual.
Posted on Sep 20, 2008
dontbother10
  • 2220 Answers
SOURCE: i have a dolmar ps 52 chainsaw keeps cutting out
Change the plug and try it. Full speed to dead stop or like running out of fuel? Reply below please.
Full speed to dead stop is an electric problem.
Slow sputting to stop most likely fuel delivery, Post back below with more detail and we can be of more help.
Lou
Posted on Mar 18, 2010
  • 4088 Answers
SOURCE: how to change fuel lines on craftmans 36cc chainsaw
The best way is to change only one at a time. There are many folks on here that removed everything, then couldn't remember where the lines went. Use original lines, not plastic. Check your work by trying to pump fuel into the primer bulb. Good luck!
Posted on Jul 18, 2010
  • 320 Answers
SOURCE: factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Posted on Apr 07, 2012
How to stop saw from bogging
Two things. First, is the chain dull? Second, if it develops a "throaty" sounds when you're cutting instead of the "crisp" sound you normally get from a chainsaw or weedwhacker or dirtbike... then the carburetor's running rich - it's "four-stroking". Try fiddling with the two mixture adjustment screws; one should be for idle mixture, the other for high-speed mixture. Get the saw idling and turn one of those screws clockwise ONE-QUARTER TURN. If the saw's idle doesn't change, turn that screw one more quarter-turn. if the saw's idle still doesn't change, thats the high-speed mixture screw.
If the saw's idle changes while you're doing that, then you're on the idle-mixture screw - return it to exactly where it was and adjust the OTHER screw clockwise a quarter-turn. Now try cutting - see if you've improved the saw's performance. If it's still four-stroking, try another quarter-turn.
If you go too far, the saw won't want to run at all at higher speeds... so you'd need to back up the screw the other way. Run it at the richest (most counterclockwise) position where it doesn't four-stroke under load.
Jul 25, 2014 | Dolmar Cyl & Piston Cpl Ps-510 - DM...
How do you test a ignition coil on dolmar ps-3410
Replace the coil I have found this is the problem most of the time
but first disconnect the kill switch wire from the coil to make sure the switch is not shorted out
Jan 22, 2014 | Dolmar New Chainsaw PS-3410 TH TLC
My ps 9010 dolmar goes dead after about 10 minutes of running
Tim:
The problem with your saw could be a few things. First, check the filter at the end of the fuel line in the tank. Sometimes the filter hangs up in a part of the tank where it is not totally submerged in the fuel. This can happen especially if you are doing side-cuts or tilting the saw. you may possibly need to adjust the fuel/air adjustment screws on the carburetor.
Jan 18, 2013 | Dolmar New Chainsaw PS-9010
Factory carb settings for dolmar ps460 chainsaw
Apr 07, 2012 | Garden
I have a dolmar ps 52 chainsaw keeps cutting out when warm any ideas thanks
Try a new spark plug first. The ignition system may be failing with heat. Try cleaning the engine with compressed air to get rid of accumulated sawdust. Check for muffler for plugging. Make sure the engine 4-strokes at full throttle, but immediately 2-strokes when cutting. Adjust the H needle somewhat to achieve this. Hope this helps
Mar 15, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
I need a coil for a Sachs Dolmar
This is a an old saw. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search for "Sachs Dolmar Super 133" and got over 10 hits.
Please search the existing posts before asking your question, the answer may have been asked and answered. It is free to join if required. They are a collection of chainsaw enthusiasts and very helpful.
This guy is a Dolmar dealer and dealt with them for many years.
http://www.arboristsite.com/member.php?u=3404
Scott has an operational radial dolmar... pretty cool. GL
Lou
I think this answers your question fully. Please rate my answer.
Sep 14, 2009 | Garden
My DCS401-16 starts w/difficulty, but won't run long, is leaking.
I suspect you have cracked fuel lines. An open line causes the saw to run lean. To large a leak and she won't run at all. Check your area for a Dolmar (owned by Makita) dealer. They sell red versions of your blue saw and for a nominal fee will be happy to help.
Lou
You own a pretty good saw.
Jun 19, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Parts manual for dolmar chainsaw made in 1987. I beleave it is modle ps7900.
Sep 18, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
