Question about SanDisk Sansa m230 MP3 Player
I deleted the music folder and nt able to play the songs in mp3
I meant to just delete songs but I deleted the entire folder and now I can't put music on. how do I get my music folder back?
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Posted on Mar 16, 2009
Plays six of twenty mp3s and the rest come up as
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete
Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Jul 27, 2010 | SanDisk Sansa e250 MP3 Player
I have a sansa e250 and i have 400 and something songs they all used to play. now only a few of them play what happened
Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Jun 26, 2010 | SanDisk Sansa e250 MP3 Player
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
There are songs on my mp3 that i dont want..
1. Plug your Kix MP3 player into the USB port. 2. In Windows, open File Explorer (right-click Start, select Explore). 3. In File Explorer, open Insignia KIX, Fixed Storage, Music. 4. Select and delete any undesired songs and/or folders, except the Music folder.
Apr 04, 2009 | Insignia Kix MP3 Player
How do I delete files?
The files on your music menu are connected to the folders on your computer. You can't delete the files from your music menu. You have to delete them (or move them) from the folder you took them from.
I suggest that you create a special folder on your computer for only the files you wish to put in coby media manager so that when you get a message like you mentioned you can get the files off your list by moving them back to your normal music folder.
I hope this helps!
_______________________
(^_^)*
Mar 31, 2009 | Coby MP-610 MP3 Player
It won't let me delete songs
  1. We Too had a hard time deleting a song but found the solution..... Put the mp3 play in the MSC mode through the settings do not put in auto.....when your computer prompts that the music player is connected it will have a screen that asks play music, open folder to veiw files..... or take no action... you neew to click on the open folder to veiw files..... when this screen loads find the song or songs that you want to delete right click and then delete it will only delete from the mp3 player.....took me two days of pissing with this mp3 player to figure it out......
Dec 15, 2008 | SanDisk Sansa m250 MP3 Player
How do you delete songs on an insignia pilot player?
Press button round one near top right side,
Go to Folder browser, rotating wheel then
press select button, in center of wheel.
rotate around and you find all your folders
on device, press select and drill down inside
of each folder, you soon see all you music.
One inside the music folder, scroll with wheel
to find names of files you want to delete
press select button, it will ask you to, Play,
Delete, Etc......
Good luck
Dec 11, 2008 | Insignia Pilot MP3 Player
My sansa c250 music folder is empty
Actually after some searching it is VERY easy to manage the c250, you just have to know how to connect it. You must connect it to read as MSC format. To do this, put on the hold feature and press and hold the rewind/previous track button as you connect it. This will open it up as a removable disc. So just drag and drop whichever songs you want from the MUSIC folder. You may also delete individual songs that are already on there. Hope this helps, works for me.
Fox
Mar 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa
I didnt get my drivers CD in my Sansa E200 pack What should I do
Dec 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
489 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
