Question about LG Televison & Video
Connecting lg br629t recorder to record foxtel
Trying to connect recorder so I can record foxtel.
SOURCE: Need to connect the following: Foxtel
how can i recover my dvdrecorder's HDD?
Posted on Mar 09, 2008
Benimur
  • 6966 Answers
SOURCE: Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 29, 2008
SOURCE: LG RH399H
I've had "Record-blocking signals detected" on my LG RH398H-M recorder off & on since I bought it almost a year ago. Also other minor problems. LG replaced the recorder 4 times with no change in problems. I became suspicious when I found that when these messages came on I could switch to any channel, digital or analog, even the weather channel, and I would still get the same message for about 5 minutes & then everything would be OK again. Recently I finally got the chance to try something. When the message came on I disconnected the input to the recorder and the message still came on! Again, I got the message "Record-blocking signal detected" with ABSOLUTELY NO INPUT CONNECTED to the recorder!!! Of course it's impossible for the recorder to be receiving blocking signals when there's nothing connected to the inputs. I wrote to LG again and threatened a law suit but so far they've been ignoring me. I would like to hear from anyone who can duplicate the above.
Posted on Jul 10, 2009
SOURCE: Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Posted on Dec 02, 2009
SOURCE: Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
Posted on May 08, 2010
Connecting set top box to dvd recorder
connect RF output of STB to RF i/p of DVD recorder.
connect stereo audio jack with same jack of DVD recorder.
now
connect DVD recorder with TV,
connect RF o/p of Recorder with TV
audio o/p with TV
Oct 20, 2012 | Televison & Video
Lg hr825t
I have the same model Dvd recorder LG but FOXTEL wont appear, there should be an AV button on the remote but there is not for the Dvd nor is there an Inout button. How do i make FOXTEL APPEAR .? all cables seem ok.. What channel is it running through ? Pls help.. Thnx
Jun 23, 2012 | LG Super Blu BH200 Blu-ray and HD-DVD...
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Recording to DVD recorder
I know you can copy to the VCR. but do not know if digital recording has any form of copyright protection. You can try to copy by connecting the outputs of the DVD TV to the inputs of the DVD player recorder.
Jul 24, 2008 | LG RC199H DVD Recorder/VCR
Connecting to a Satellite reciver
I solved the problem with my DVD recorder. I attached a cable from the loop out on the back of the FTA receiver to the RF in on the back of the recorder. All I was missing was the signal from the satellite. Everything is working fine now.
Thanks
JimCee
Mar 23, 2008 | LG Televison & Video
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
63 people viewed this question
Computer Repairing
Computer Repairing
