Question about Sony VAIO GRV680P Notebook
Sony Vaio PCG GRV680
Machine is dead. When I press start button, nothing happens! It's been running funny for a while now. Always started up though but didn't always initiate windows o/s. Now it's dead. I don't know what to do. It's an expensive 17" machine and I'm feeling really bad about throwing it out.
  • Anonymous Mar 13, 2009
    Dear Blu3Demon,
    It seems there is no power to machine. I don't know what else to say about it. I plug it into electricity and press start and nothing happens whatsoever. It's completely dead. Like other people have been reporting about the Sony Vaio - a very expensive paperweight. As I said before, recently it would power up but would not initiate the operating system windows xp, so I kept shutting it down by pressing the start button for five seconds and trying again. It would initiate the o/s usually only the first time each day; if I tried later in the day, it would power up but not initiate windows xp. I'm really looking for help; don't want to buy another computer since this one is really dynamite when it works. Thanks for your help.
  • Dwayne Dennis
    Dwayne Dennis May 11, 2010
    So theres no power to the system
Sony vaio PCG-61211M wont turn on and the power button starts flashing on and off
This can be a sign of a discharged battery, and this may be due to a faulty adapter or the connection in the laptop.
Dec 13, 2013 | Computers & Internet
Resetting vaio GRV680 to factory settings
You will need a restore disk that came with the machine if you got one or a restore partition on the hard drive or you need a genuine copy of your version of windows.
May 05, 2012 | Sony VAIO GRV680 Notebook
Sony Vaio PCG-9336: Dead machine - Hybernation?
Plug the thing in and recharge the battery for about 6 hours then push the power button to turn the thing on.
Oct 30, 2009 | Computers & Internet
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
fix first the power adapter/ it not charging some problem of your power adpater,, check the charger if it is working properly or not, then follow by dc connector should know that your dc connector has no deffect// if its okay check the motherbaord of your pc maybe som chips need to replace or damage...ic capacitor fause..ech..
Sep 10, 2009 | Sony VAIO PCG-K23 Notebook
If you will turn your VAIO upside down you will see reset button. You can press that with pin,. This will reset camera. Reinstall camera drivers after reset and camera should work.
Apr 09, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Won't stay on
you probably need a power supply
before you run out and buy one start and press f8 then start in safemode see if the same thing happens
also make sure your AC adapter is connecting with internal connection the internal connection can become loose or bent from constant plugging and unplugging
Jan 22, 2009 | Sony VAIO PCG-K35 Notebook
PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
Jan 21, 2009 | Sony VAIO PCG-K35 Notebook
Laptop vaio pcg-v505ec doesn't power up
try taking out the battery and running it from the power pack only
Nov 21, 2008 | Sony VAIO PCG-V505EC Notebook
Pcg-fxa49 won't boot
Could be it needs the DC jack resoldered or replaced. (Sounds like its trying to start off dead battery).. These arent to bad to do compared to others weve repaired. Good luck!
Jan 29, 2008 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Sony VAIO GRV680P Notebook Logo
126 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
