Question about Hobart Welding Tools
I need to know if they still make hobart desiel welders,2 cylinder, 1800rpm,115 volt? if so, what problems do they have? and is $1500. for a used one a good price or not.
    Problem Solver:
  • 14 Answers
Go holbart web sight and look them up hope this helps jojogunne
Posted on Mar 15, 2009
My hobart handeler 125 will not stop feeding after i release the trigger, why?
The trigger is bad in the gun. It sound like the spring is bad, or you have some junk in the trigger not alowing it to release. Remove and inspect/clean the trigger.
Nov 04, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Where can i get parts for my hobart welding machine but is a old welder
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
Oct 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
I have a maxstar 150 tig welder that i take with me in our race car trailer, the trailer has a 6.5KW onan NHE generator in it, the welder fails to turn on with this generator, i checked volatge and freq...
Here is the spec sheet for your welder. The only problem that I can see is maybe your power cord is too small. As you can see on the spec chart, the minimum the machine will draw at 115 volts is close to 20 amps. Now your have to multiply that by 1.5 for transformer surge. So now you are looking at 30 amps, which means you will need size 10 gauge wires in your extension cord. If you are going to do some heavier welding, you may even need to go to a #8 cables. What happens also, when you try to draw a lot of current, the generator will bog down, thus providing less power. It would be better if you could use 230 volts. https://www.millerwelds.com/pdf/spec_sheets/DC27-1.pdf
Oct 23, 2017 | Miller Welding Tools
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
My fm140a will not feed wire
You may need to adjust the tension just in front of the wire spool
Your gun liner maybe shot
Dec 28, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire feed motor not working
I believe the circuit card assembly has failed. It is very rare that the motor is the problem.
Sep 30, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Northern tool brand wire fed gasless welder feeds wire fan work no welding?
You need to have the ground attached to what you'll be welding on. Make sure there isn't anything on the end of your wire. Also, if your voltage is all the way down it won't do anything either. Oh, one more thing, make sure you have a contact tip on the end inside the cone. That will be the copper thing the wire goes through with a really small hole. I know some of this sounds pretty obvious but if I hadn't done these things at least once.....I wouldn't know what to look at either. I also don't know your experience level and want to cover all avenues. Hope you find it!
May 20, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Welding Tools Logo
63 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
