Question about Alpine Type-R SWR-1222D Car Subwoofer
I have a small crack right under the Q on my quantum audio 12'' sub. is it safe to pop out the middle cap and let it beat or should i use silicone to fix it?
    Problem Solver:
  • 4 Answers
Hi there
i beleive that underneath some dustcaps is unsealed. the dustcap in some subs encloses the motor that drives it. I would suggest getting it fixed in 1 way or another just incase. Having the motor exposed( if it is) can burn out if unattended to.
I hope this helped.
thanks jeremy
Posted on Mar 13, 2009
We have a toilet problem now for 8 years since we bought our place,the toilet leaks onto our bathroom floor we know where the leak is someone have put silicone around the plastic valve right @ the bottom...
With out seeing it, it is hard to actually know what the problem is, but it sounds like it is either where the water line enters the tank, or the gasket between the tank and the bowl. Either way there should not be any silicone. The water line flows into the fill and shut off valve. If it is leaking from there get a whole new valve for under $20.00. For the gasket between the tank and the bowl you have to remove the tank and replace the gasket.
What many people are unaware of is a small crack in the tank and rarely a small crack in the bowl. If the leak is not from one of the two things I mentioned above it has to be a crack and in that case a new toilet.
If you can not tell where the water is coming from it could be a crack or the wax ring under the toilet may need replaced. You might want to call a plumber and get a free estimate on what the problem is.
Good luck with this.
Rick
Mar 11, 2013 | Toto Round Carusoe Two Piece Toilet, 1.6...
The foam around the sub is cracking is not all the way throu but i think it will go all the way soon what can i do to prevent this from happening can i add some silicone to the crack so it will stop from...
Send any damages speakers to these guys : http://www.speakerrepair.com/
The foam in critical to locate the magnetic cone correctly, silicone will not do that. The repair is quite reasonable and my speaks worked correctly when I got them back.
Feb 16, 2011 | Jl Audio W7 Woofer
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
Jan 12, 2010 | Car Audio & Video
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
12'' sub woofer
cone is cracked if you see the crack sometimes epoxy or rubber glue can wrok but Id ship it back to audiobahn if under warranty otherwise buy another one as shipping and repair gets expensive
Apr 25, 2009 | AudioBahn AWES12P 12" Subwoofer Car...
I have a cracked sub for a car system 12''
you would be amazed what a little clear silicone will do make sure you apply to both sides using a popcicle stick spreads it on nicely or try using a hot glue stick try it it will work
Dec 14, 2008 | Infinity 1250w Car Subwoofer
Hi, i have jbl 1201.1 running 2 audiobahn aw1200v subs, i used to have 2 jl audios but the amp blew them, when i turn up to about 32 volume the subs cut out, they come on and off, amp doesnt go into...
well first off the cap should be reading 14.00 volts not 12 but check on ur settings maybe its to high if that dont work then ur amp or amps is way to powerfull for those sub or theres not enough watts from the amp to the sub causeing the amps to under power the subs but let me no if u got it im all wayz here to help
Apr 04, 2008 | Car Audio & Video
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Alpine Type-R SWR-1222D Car Subwoofer Logo
69 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
