Question about Akai LCT2721AD 27 in. LCD Television
Tv not working..light keeps flashing
My tv was fine last night and when i went to turn it on this morning the green light would come on then go right back to red...i unplugged it for a few then when i turned it back on the light just kept flashing and some noise that goes with it that sounds like when you first turn it on..i have to turn it off from the other switch just to stop it from flashing and making that noise.. i have my tv up on a tall dresser by my doorway in the bedroom and where i live my room is right off the kitchen across from a wood stove so not sure if the heat coming in from that has made it too hot or if maybe if because it gets so dusty in this house if maybe dust has gotten into and that's what the problem is.
  • 33 Answers
I had same problem with my Sony. Unplugging from wall for 36 hours solved the problem.
Posted on Aug 31, 2009
2 Suggested Answers
  • 1039 Answers
SOURCE: TV stand stuck to dresser
Try spraying a little water near the feet and apply heat from a blow dryer. Not too much don't want to melt anything.
Posted on Nov 24, 2009
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV WENT OFF BY ITSSELF
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
Akai LCT2721AD 27 in. LCD Television Logo
183 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
