Question about Miele Novotronic W1918A Front Load Washer
Miele w310 will not go through cycle and rinse lights flashing
  • 16 Answers
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Posted on Feb 08, 2008
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
SOURCE: rinse light flashing on miele
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Posted on Mar 14, 2009
  • 14 Answers
SOURCE: rinses light flashes miele w864
this usualy indicates a problem with the motor not turning, it can have many causes
Posted on Aug 26, 2009
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Miele Novotronic w310 washing machine - won't spin and flash 'rinse' on the display?
Did you try to set the temperature to the minimum?
Maybe the heating element is faulty....
Nov 30, 2015 | Miele Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
I've bought a Miele W310 front loader, which is secondhand, so i don't have a manual. i would just like to know how to do a short wash. There are buttons: 'Short' 'Prewash'...
The short cycle is only an option for Cottons. Make sure that you have set the desired program temp for a cotton cycle (95-30 degrees C). You should be able to select the Short cycle by pressing the button below the Soak light several times. (Note: this cycle is for small amounts of clothing which are lightly soiled - use less detergent (1/2 the amount for a full load).)
If it doesn't work when on the Cotton cycle, then the switch inside the control panel may be faulty.
The manual is available from Miele, http://www.miele.co.uk/customer/OperatingInstructions.aspx . Enter the type of appliance and then scroll down the list. The direct link to the manual for the W310 is http://www.miele.co.uk/Resources/OperatingInstructions/W%20310.pdf .
I hope this helps.
Jun 25, 2011 | Washing Machines
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Nov 16, 2008 | Miele W310 Front Load Washer
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W1918A Front Load Washer Logo
98 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
