Question about Kenmore 62622 Electric Dryer
Dryer will not run
I Checked circuit in home, all good. Switch is clicking and power cord looks fine. I need to get to Fuse in dryer but Cannot get back off. It seems to be riveted, how do I access the fuse to check it
  • jjnjj Mar 12, 2009
    Thank you, got access and of course it a mess in there. I do not have much room to manuever and I have no idea what I looking for. Where is the fuse??
  • Kenmore Master
  • 3,361 Answers
If the back of your dryer is solid your access is through the front.
Raise the lid, then remove the front panel.
Remember to unplu the dryer.
Posted on Mar 12, 2009
  • steve
    steve Mar 12, 2009
    There should be 2.
    One immediately in front of you on the exhaust vent.
    One behind the thermostat on the heater canister.
    Remove the wires from them.
    Use you meter set to OHMs or continuity and touch each terminal with the meter leads.
    No reading.
    Bad part.
    Reading.
    Good Part.
  • steve
    steve Mar 14, 2009
    Did you check it yet?
Dryer won't start, light is off, but fuse is ok
Had a similar situation after running the dryer for multiple loads. I checked the wiring schematic and found the overload thermal switch location on the exhaust duct. Using my $4 volt amp meter I checked and found the circuit open (the switch open circuit). Removed the switch, went to the appliance parts store and bought a replacement for an exorbinant $9. Installed the switch and it has worked for the past couple of years.
Now that was my solution. You will need to check the wiring diagram for the problem. I would not buy a new dryer just yet until looking for a simple switch or contact that isn't working.
Dec 20, 2012 | Whirlpool LEB6300 Electric Dryer
Does nothing when you press start button. Have checked the door switch, the start switch, the plug, the cord all with ohmmeter and they are all fine. Circuit breaker is good. I am at a loss. Wife had...
This is a simple dryer. the thermal fuse is mounted on the heating element. Clear any air restrictions that would cause dryer overheating before replacing that fuse. If the fuse is good then the door switch is the next most likely place to lookthemobilian_375.jpg
Manual and more here
Dec 06, 2010 | Amana NDE2330AY Electric Dryer
My dryer is an estate whirlpool dryer does not heat. The heating element and both the thermal fuses check out okay. Is there another switch I need to check? I also cleaned out the vent. Fuse box checks out...
I'm assuming from the symptoms you posted, that the dryer does run, correct? If so, the fuse box may have checked out, but have you also checked for the correct voltage at the wall receptacle? A dryer will still run, but will not heat, if its missing a portion of the input voltage. The reason is that the drive motor only uses 120VAC to run, while the heating circuits need the full 240VAC service. If you are missing one leg of the input voltage, the dryer will exhibit the symptoms you describe. In addition, depending on when your home was built, some houses use two separate breakers that feed the 240VAC source the dryer needs to run. Have you checked to make sure there isn't more than one breaker that feeds the dryer? If you have checked for the correct voltage, have you also checked the continuity of the power cord to the terminal block? A broken power cord can give the same symptoms.
If the model number is correct, this is a very simple dryer to work on. There are no other switches or relays, other than the door switch and the built in centrifugal switch inside the drive motor. If the door switch were bad the dryer would not run at all. If the centrifugal switch in the motor were bad, the dryer may or may not run (depending on how it is faulted), which may give you the symptoms you describe.
When you checked the components, how did you determine they were good? If you need assistance (just to clarify your measurments), the following two links can give you some tips on how to troubleshoot this problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
I hope I'm not insulting your itelligence. I ask these simple questions, because they are things that can easily be overlooked. If you need further assistance, please post back and elaborate a bit more on your symptoms, so i can provide you with a more definitive answer. I hope this information was helpful to you.
Jun 30, 2010 | Estate TEDX640JQ Electric Dryer
Dryer won't start when i push the button,checked breaker,removed back,i believe there is power to switch.what di i need to check for?
If your model number is correct, all the heating circuits on your dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
This component will blow in an overheat/over-current condition and must be replaced. Usually when this component fails, it fails for a reason. Check your blower fan housing for any clogs or obstructions that may be causing the dryer to run hot.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3 for item 19 (part number AP3132867).
Something else to consider:
1. Does the dryer have multiple breakers? An electric dryer runs on 220VAC. Some home use two 110VAC breakers instead of one 220 breaker. Double check your power distribution and make sure you have the breaker(s) set properly.
2. Have you checked the voltage at the wall receptacle? Unplug the dryer and take a voltage reading across the two hot (left and right slots) terminals. If good, you should read 220-240VAC.
3. Have you verified the power cord is good? You can check the power cord by leaving the dryer unplugged and remove the back panel where the power cord is installed on the back of the dryer. This is called the terminal block. You can either perform continuity checks between the prongs on the cord to the terminals at the terminal block, or you can plug the cord back in and take a voltage reading across the RED and BLACK wires at the terminal block.
If good, you should read the same 220-240VAC that you read at the wall receptacle.
If continuity is good you will read 0 ohms resistance from the end of the power cord to the terminal block.
4. Have you verified the door switch? When you open the door is the drum light on? With the dryer plugged in, you should be able to open the dryer door and see the light on insode the drum. Toggling the door switch with your finger, this light should go out if the switch is making contact. If the switch is defective, the dryer will not run.
I hope I've given you enough items to consider. If you have any questions, please let me know. I hope you find this information helpful.
Jul 30, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer power but won't run
A thermostat will not keep a dryer from running, but a broken belt will. If the model number you have this listed under is correct, you can access the dryer interior by lifting the lint screen door on top of the dryer and removing the two screws. With the screws removed, the dryer top will lift up. The belt should easily be seen wrapped around the dryer drum. If you pull on it, the belt should not have any play in it. If the belt is broken, it needs to be replaced. If the belt is loose, it probably has come off the belt tension idler pulley and needs to be reinstalled. Another common problem is a blown Thermal Fuse. All the heating circuits this model dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3. The Thermal Fuse is listed as item 7.
Something other things to consider:
If you have any questions, please let me know. I hope you find this information helpful. NOTE: The start switch popping back out when you open the door, I would assume to be normal. The dryer is supposed to shut off when the door opens.
Jul 30, 2009 | Whirlpool LEQ9858L Electric Dryer
I have a whirlpool dryer, model number GEC9858EQ0, that did not restart after opening door to check the laundry. I have ohms checked the start switch and door switch. where do I go next?
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
    Good luck
  • Regards:
  • VOTIT
Jul 01, 2009 | Dryers
No power at all. checked circuit braker, made sure door closed, cord is plugged in.
Check fuse near power supply. If fuse and relay are good, try playing with door switch. If no difference, than the power supply itself will need to be changed
May 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not start sometimes, could this be the on off swith?
When a dryer won't run, there are several things to consider:
  • Is the circuit breaker thrown? Can you read 240 volts at the wall plug?
  • Are the wires at the power cord burned? (Very common)
  • Can you read continuity thru the door switch? Does the door switch click when closed?
  • Check for a belt switch near the motor....this will cause the dryer not to run if open.
  • Have you checked the thermal fuse?
  • ===you need a good meter to check all of this=======
Was this helpful?
Mar 15, 2009 | Roper REX3614KW Electric Dryer
Kenmore electric dryer
ck door switch also ck connection of power cord could be burnt remove back (if top mount filter lower panel if door mount)look for white thermal fuse ck for closed circuit through fuse fuse is in motor circuit and has been known to blow for pluged or restricted vent system
Jun 10, 2008 | Kenmore Dryers
Kenmore 62622 Electric Dryer Logo
172 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
