Question about Acoustic Research Audio Players & Recorders
I have 1 speaker of Acoustic Research of 312 HO.
What do i need to use it?do i need a amp?
  • 65 Answers
You have only one? or one pair? this standing speaker need a Amp to drive.
Posted on Feb 04, 2014
JigSaw007
  • 157 Answers
SOURCE: Acoustic Research AR1 HiRes subwoofer amplifier
hello sir
Posted on Aug 25, 2008
sleepy_user
  • 140 Answers
SOURCE: Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Posted on Jan 29, 2009
ripleymojica
  • 643 Answers
SOURCE: I want wireless speakers for a 25'X 30' room to
they are wireless but need to be plugged in for power. or batteries. can be used as mono or left and right. i sell these spkrs and have had no complaints. hope this helps.
Posted on Jul 10, 2009
  • 317 Answers
SOURCE: Looking for an owner's manual for Acoustic
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Posted on Sep 17, 2011
bigbudget
SOURCE: Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
Posted on Oct 26, 2012
There are 2 wires from crossover to Acoustic Research Phantom 8.3 Titanium Tweeters. One wire is Brown, other Green. Tweeters have one terminal marked with red paint. Some of my speakers have Brown wire...
Normally Speaker and Amp side will mark correctly the polarity. If wrongly connect phase may get wrong. If you understand or may know the different by hearing, if both tweeter phase is wrongly connect, what need to do is reverse the connection of one side the phase will change. you can try which give you the best listening feeling.
Feb 08, 2013 | Acoustic Research Phantom 8.3 Main /...
Woofer sound distorted
What audio source you put into your Amp? you can lower the source volume also the amp volume to confirm, where the problem come.
Source input is also important whether you using low level or hi level input.
Nov 18, 2012 | Acoustic Research P315 HO Speaker
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
Woofer maiking a loud noise
be more specific, what type of noise? Humming noise or cracking noise or pop noise? can you still hear noise without signal input line connected?
Mar 05, 2012 | Acoustic Research 308 HO Speaker
Looking for an owner's manual for Acoustic Research 310HO loudspeaker. I would like to know the correct crossover frequencies for bi-amping.
Try
mauritron.com
and
Sep 17, 2011 | Acoustic Research 310 HO Speaker
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
May 20, 2010 | Acoustic Research AR1 Speaker
Acoustic Research ARS115PS Subwoofer, No Sound
I have the same problem with the smaller AR 112PS speaker and since Acoustic Research went out of business, I too have been looking for a solution. I may have found an alternative to throwing away this really nice speaker. I found a company on the web that appears to sell an amp that may fit nicely into this speaker enclosure for $99.00. Check it out...
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-805
Tenderfoot56
Feb 27, 2008 | Acoustic Research ARS115PS Speaker
88 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
