Question about Murray Garden
WHAT SIZE SOCKET FOR MURRY 760-770 BLADES
WHAT SIZE SOCKET TO REMOVE BLADES
2 Suggested Answers
  • 43083 Answers
SOURCE: I have an 82 murry garden tractor 18 hp42" mower deck and I have no idea which size blades to use and what hardware to use to mount the blades on the shaft. It has a 3 blade system
measure one of the old ones . only way I know of to get the right size .
Posted on May 13, 2016
Blade screw keeps turning when trying to replace blade
remove the power lead from the wall socket
put a screw driver in the teeth of the blade and use it as a stop against the guide
use the right size spanner and undo the blade retainer nut
Aug 21, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
How do you remove mower blades on john deere lx188
Get yourself a rattle gun connect it to an air compressor with the right
size socket hold the gun on reverse it should remove the bolts.
Apr 22, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Removing blades from a john deere eztrak z425
I have the same problem. 3/4 in. too big, 11/32 too small, 19mm too big, 17 mm too small. I don't have a 18mm or 21/64 in any of my wrench sets because they are not common sizes. I guess I'll have to contact JD.
Apr 22, 2012 | Garden
Sounds like gears are slipping and blades stop turning. no obvious damage to drive socket or gear on end of blade shaft.cant remove drive socket any suggestions on removal? Blade assy fits very loosly into...
First thing is to find the small hole on the plastic piece below the drive socket and remove the silicone in from it. Next turn the drive socket until the little arrow on the drive socket lines up with the hole, then look thru the hole to see the allen wrench screw in there loosen screw to remove drive socket.
Sep 15, 2011 | Vitamix 5000 Work Top Blender
Heater, and air conditioning not working. All fuses and relay switches are functional, but no power to heater.
  • Disconnect the ground cable from the negative battery terminal by loosening the retaining bolt and pulling the clamp off the terminal.
  • Locate the heater motor access panel. It will be a flat piece of black plastic underneath the dash on the passenger side of the Caravan, just behind the glove box. Use a socket to remove the five screws that secure the access panel to the dash.
  • Disconnect the plastic electrical connector from the heater motor by prying the retaining tab away from the connector with a flat-head screwdriver and pulling the connector off the motor.
  • Use a socket to remove the four screws that secure the heater motor to the dash. Pull out the heater motor and fan blades as an assembly.
  • Remove the nut in the center of the fan blades that secure the fan blades to the motor's shaft.
  • Dec 06, 2010 | 1992 Plymouth Acclaim
    I would like to know the best way to change the blades on a42in lawn tractor it has 2 blades thanks
    The very best and easiest way to remove the blades is with an air impact wrench. With an impact wrench it is simple as you do not even have to hold the blade, but with a ratchet and socket you must hold the blade while trying to remove the bolt. Use a piece of wood to wedge the blade so it cannot move.
    Apr 24, 2010 | Garden
    I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
    If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
    Oct 20, 2009 | Tools & Hardware - Others
    I have a Murray 40 inch riding lawn mower and I had to replace the blades - which I did but when I went to mow the lawn it dug up my lawn so I thought I put the blades in wrong so I reversed the blades and...
    It sounds like your mowing deck is too close to the ground. Can you adjust the blade height with a lever? I have a Craftsman riding mower, my deck height is adjusted manually with the use of a locking level shifter, be sure yours is set to the proper minimum height and this will eliminate driving the blades into the turf.
    Sep 21, 2009 | Garden
    Garden Logo
    Top Murray Garden Experts
    Dennis Key
    Dennis Key
    Lawrence Oravetz
    Are you a Murray Garden Expert? Answer questions, earn points and help others
