Question about Lionel (31956) Thomas The Train Set
Thomas engine keeps uncoupling.
Looks as if the spring on the engine is weak. Is there fix I can do to this? Or am I doomed to return it?
  • 40 Answers
Check the warranty. If still under, return it. Otherwise find a store that sells small black rubber bands, around 1/2" in diameter. Wrap one around the coupler behind the knuckle. Check to see if the coupler still opens. If it does move the rubber band either forward or backward until the coupler does not open.
Posted on Dec 04, 2013
My 97 royal star is stuck in second gear, I just bought it was st ride exept not 1st gear , it looks like someone just changed clutch
Hi, Janice and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
shifter still stuck
The Venturers Yamaha Venture Technical Support Library
Yamaha XVZ13TFL Service Manual
OEM parts for Yamaha
YAMAHA XVZ1300A Owner Manual
Apr 29, 2017 | Yamaha Royal Star XVZ 1300 A Motorcycles
My land rover defender diesel, keeps accelerating after pedal was released. How can I fix it?
Check the return spring has,nt broke ,check cable or linkage is operating freely or fit a return spring.
Oct 27, 2015 | Defender 1984-1992 Land Rover w/ 0-3 inch...
How can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
How can I fix the pulley system on the Thomas and Friends ...
www.fixya.com/support/t25901578-fix_pulley_system_thomas_friends
Oct 10, 2015 - We have a Thomas and Friends Shipwreck rail set. In the mast part of the ship the string has come off one of the wheels. Need to know how to ...
We have a Thomas and Friends Shipwreck rail set. In the ...
www.fixya.com/.../t26065033-thomas_friends_shipwreck_rail_set_in
6 days ago - Question about Thomas and Friends Dolls, Playsets & Toy Figures .... can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
Fisher Price Thomas & Friends TrackMaster Shipwreck ...
www.soap.com > Holiday > Hot Toy List
Rating: 3.5 - ‎84 reviews - ‎$70.79
... return policy. Shop Fisher Price Thomas & Friends TrackMaster Shipwreck Rails Set at Soap.com. ... Second time the whole system of springs and pulleys blew apart.... In looking for a on line tutorial fix found out this is a reoccurring issue.
Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co ...
www.amazon.co.uk/Thomas-Friends...Shipwreck-Rail...
Amazon.com, Inc.Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co.uk: Toys & Games. ...
Oct 10, 2015 | Thomas and Friends Toys
Thomas the Tank engine coupler not holding on the cars.
Apr 23, 2013 | Lionel (31956) Thomas The Train Set
I have a 1979 yamaha gt 80.i was riding and shifted into 3rd and now its stuck there and i cant shift up or down.why is that
Hi, Anonymous and the usual suspects are:
1982 GT 80 Enduro Wont shift
Fixing the 2nd Gear on Yamaha Triple Engine
YAMAHA DT80 DT100 GT80 FULL SERVICE REPAIR MANUAL 1977 1982 Download... $18
1979 1980 YAMAHA GT80 GT 80 FACTORY OWNERS Manual OEM BOOK 80 eBay
Apr 16, 2012 | Yamaha Motorcycles
Stuck shifter on 1973 yamaha 360 enduro. how do i fix it?
HELP MX250 engine stuck in neutral will not shift Vintage Enduro...
http://www.vitalmx.com/forums/Race-Shop,42/Bike-stuck-in-1st-geat,450813
DOWNLOAD NOW Yamaha DT250 DT360 DT 250 360 Service Repair Workshop Manual... $15
http://mybikemanuals.com/yamaha/yamaha-dt
Mar 20, 2012 | Yamaha DT 360 Motorcycles
I retrieved codes 1260 1251 and 1231 with a snap on versus. it will not give me any code descriptions. will not idle on own. vehicle seems to misfire will holding throttle to keep running. after i clear...
CODE P1260 THROTTLE RETURN SPRING WEAK SPRING FORCE. CODE P1251 THROTTLE POSITION MOTOR FULLY CLOSED POSITION. CODE P1231 THROTTLE POSITION SENSOR 1 AND 2 RANGE PERFORMANCE PROBLEM. SOUND LIKE PROBLEM IS MECHANICAL PROBLEM.YOU HAVE WEAK THROTTLE RETURN SPRING.GO TO DEALERSHIP PARTS DEPARTMENT FOR NEW RETURN SPRING.
Jan 15, 2011 | 2000 Saab 9-3 Viggen
When I turn sharpling left or right(like parking) there is a binding noise ,but not driving straight or normal speeds. 0there is a binding
this is a verry common problem with the awd bravada a tsb was sent out telling you to change the transfer case fluid to gm tract 2 fluid well let me tell you my story first i am a mechanic of 40 + years i have a 2000 bravada awd i changed the fluid 2 times like the tsb says no fix got a low mile used transfer case instaled it put the trac 2 fluid in it no fix replaced the awd module no fix so i decided to take my old transfer case apart and see what makes it tick i found out that a spring pushes the clutch fork to disingage the front drive shaft clutches the encoder moter applys the fork sending power to the f drive shaft the spring was weak and did not disingage the cluch pack THIS IS AN EASY FIX but you should replace the fluid first if it remains the same then remove the plug in the bottom and i mean the bottom of the transfer case cant miss it it looks like a tall bolt when you remove the plug a spring will come out with it i shimed my spring about a 1/4 inch PROBLEM GONE i tested this on my old transfer case on the bench first and it worked fine i also tryed streching the old spring that did not work maybe replacing the spring with a new one might also work also i would think a new encoder motor might return to rest easer then an old one this spring is what returns the encoder motor and pushes the clutch pack to 2wd
Dec 16, 2009 | 2000 Oldsmobile Bravada
Clutch sticking on 2000 pontiac firebird trans am. clutch comes halfway up but need to pull it up the rest of the way w/my foot.
There is actually a fix for this problem. There is no return spring for the clutch being that it is hydraulic. You need to take the master cylinder out and drill the return line an 1/8th of an inch. The reason why it sticks is because the return line is too small. All the fluid is backed up and once it is cleared, the clutch will return to normal. There is an article in GM High Performance magazine online that has the step by step instructions to fix it. Hope this helps.
Aug 28, 2009 | 2000 Pontiac Firebird
Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
Lionel (31956)  Thomas The Train Set Logo
196 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
