Question about Canon imageRUNNER 2200
The cannon imagerunner 2200 shows the error code E000051-0000
What do we have to do to get the machine functional again? thanks
  • 1 more comment
  • perfecttimem Mar 13, 2009
    I did ask a question: "what do we have to do to get the machine functional again?" We have tried turning the machine off and on, unplugging it etc... It continues to show that error code and I do not know how to make it function again.
    If the error code is not being shown - it is:
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    You will gete a answer when you ask a question??
  • Anonymous May 11, 2010
    "the error code"....??
  • Canon Expert
  • 1,326 Answers
Have you worked on the copier or has a service person just worked on the copier? The error code deals with the motor M3 not getting a signal to turn ON. Make sure you turn the copier Off and unplug it from the wall...... Then take the back cover OFF and look for connector J3040-2... The connector is most likely only part way in... Disconnect and reconnect it... Also, make sure all the other connection are all in correctly.... Good Luck.....
Posted on Mar 14, 2009
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
CAnnon Imagerunner 2800 Error code: E000002 0000
Jan 18, 2011 | Canon (6981A002AA) for imagerunner 2200,...
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
Sir my canon 3300 error e00000-0000 pls help me
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
plz do rate solution if helped
Nov 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Sep 25, 2009 | Canon imageRUNNER 2200
Wats the meaning E00602-0003
Call the serves and must support you
or cheak un cannon site what the error
Dec 15, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Aug 26, 2008 | Canon imageRUNNER 2200
Canon iR2200
press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Jul 14, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Canon imageRUNNER 2200 Logo
317 people viewed this question
old marine
old marine
