Question about Lionel (31956) Thomas The Train Set
Thomas the Tank engine coupler not holding on the cars.
Keeps uncoupling from the cars as we increase the speed. Looks as if the spring on the engine is weak. Is there fix I can do to this? Or should I take it back?
  • 40 Answers
Check the warranty. If still under, return it. Otherwise find a store that sells small black rubber bands, around 1/2" in diameter. Wrap one around the coupler behind the knuckle. Check to see if the coupler still opens. If it does move the rubber band either forward or backward until the coupler does not open.
Posted on Dec 04, 2013
My 1972 volvo penta aq130 idle speed increases. is it a worn screw or spring or?
could be a spring problem but if idle speed slowly increases then it indicates that the air/fuel mixture is going lean
low float level, tank nor venting properly, fuel pump problems etc
Jul 17, 2017 | Garden
Have Craftsman 6.75 lawn mower, briggs Stratton engine. How do I adjust running speed ??
Are you familiar with governor speed regulators on engines? There is a flap on a hinge under the flywheel cover which is moved by the air fins on the flywheel, which tries to close the throttle. There is also a spring that tries to open (increase) the throttle. So it's a contest between those two opposing forces! Increase the spring tension, and you will have more speed. But don't overdo it, or you could blow your engine! Good luck!
May 12, 2017 | Craftsman Garden
My rocam 1.6 how do i know if its my hydrallic lifters making a noise
If the noise goes away when the idle speed increases its not the lifters, check the oil pressure is ok at idle and increases with engine speed, check the oil is not to thin or wants changing, the oil pump relief valve may be stuck or the spring spring broken.
Aug 10, 2016 | 2006 Ford Bantam 1.6i
I have KIA sorento 2.5 diesel 2009 model and it was overhaul engine and now the the oil lump keeps on flicking when reducing speed or idling after getting warm, What could be the problem
Remove the oil sender unit, fit a oil pressure gauge , start the engine and read the oil pressure at idle engine hot, must read above 10 psi and needle not flicking, must increase with engine speed , if pressure is ok replace censer, if not check oil pump screen and relief vale spring, can also be caused by crankshaft bearings clearance .
Jul 02, 2015 | 2007 Kia Sorento 4x4
Thomas engine keeps uncoupling.
Apr 23, 2013 | Lionel (31956) Thomas The Train Set
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
Low RPM's
I know this is an old post but I figure maybe my solution will be found by someone else doing a Google search and it can help them. Hopefully, you've gotten yours fixed in the 10+ months since you asked this.
Anyway, if you remove the top plastic shield from the mower (two screws hold it in place, plus a small cover near the air filter that needs to be removed) you will see a small spring that attaches to a tab at the front of the mower. If you bend that tab forward it will put more tension on the spring and increase the engine speed. You'll know if you are looking at the correct spring if you lightly press on the spring and the engine speed increases.
It is a good idea to monitor the adjustment with a tachometer. My owner's manual says the engine has a 3,100 max rpm. You don't want to set it above the specified rpm or you'll probably burn the motor up in a short time. I set mine at 3,060 rpm. It's hard to get it perfect but I figured slightly low is better than too high. Mine had been running at 2,800 rpm.
I bought a small engine tach on eBay for around $9. The wire wraps around the spark plug wire 4-5 times and then you can read the engine speed. It also keeps track of how many hours the engine has been running. I figure that will come in handy for oil change intervals so I permanently mounted it to the mower. It almost looks like it came that way from the factory. :-)
Here's the tach I bought: Hour Meter Tachometer 2 & 4 Stroke Small Engine
Aug 26, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Tecumseh engine #143.985510 - carb linkage hook-up
Hello:
The Carbuertor Throttle is Held in the Full Open Position Until the Engine is Started and Running, then the Governor and Spring Work together to Keep the Engine RPMs to the Desired Setting.
The Following is an Explaination on How the Governor System on Small Engines Function.
>>The Governor System behaves like an Unending Tug of War between One of Two Governor Springs, which Pull the Throttle Toward the Open Position, and a Spinning Crankshaft, which Tries to Close the Throttle. When the Load on the Engine Increases - a Typical Example is when you Move your Running Lawn Mower from the Driveway to the Grass - Crankshaft Revolutions Drop. But the Governor Spring is Still Tugging, Causing the Throttle Plate to Open. In Response, a Larger Volume of Air-Fuel Mixture Enters the Carburetor, Increasing Engine Speed to Compensate for the Increased Load. The Crankshaft Speeds Up, and the Tug of War Resumes, until a New Equilibrium is Achieved. With Each Change in Load, the Tension Between the Governor Spring and the Load Brings about a New Equilibrium, known as the Engine's Governed Speed. Neither Side Wins until the Engine is Shut Off. At that Point, without the Crankshaft Spinning, the Governor Spring Pulls the Throttle to the Wide-Open Position. Two Types of Governors are Common on Small Engines - Mechanical and Pneumatic.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Garden
2008 1200 rt-p engine rattle during high speed deceleration.
keep on your dealer on your drive there is a spring pressure that holds a coupler together look at pic .
this is where we have had problems with the older ones
Nov 17, 2008 | 2007 BMW R 1200 RT
Lionel (31956)  Thomas The Train Set Logo
94 people viewed this question
Top Lionel Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
