Question about Kohler Home
Sewer smell drain
We live on the 4th floor and we get a sewer smell during use especially after use. I have checked out acouple of other 4th floor toilets and do not detect the sewer smell. I can't live with this.
  • 2,355 Answers
Are there any floor drains in the room and an unused bathtub or shower? if so the water may have evaporated from the trap and allow the sewer gas smell. try pouring water into all the drains and see if it is still happening. more elaborate problem may be a broken vent stack in a wall.
Posted on Apr 09, 2015
    Top Expert:
  • Kohler Master
  • 43,901 Answers
There may be something clogging the trap. You can try an applicartion of toilet cleaner, NOT ordinary drain cleaner to see whether the problem goes away. You may have to repeat the process a few times
Posted on Apr 23, 2013
SOURCE: Our new Toto Drake toilet is experiencing some
We invited Roto Rooter out and he had it snaked out in about 2 minutes flat! No more problems for now. I think we need to purchase one of those tools!
Posted on Oct 06, 2009
projdoc
  • 2237 Answers
SOURCE: toilet wont flush completely. it may take 4 times
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Posted on Nov 13, 2009
  • 760 Answers
SOURCE: sewer oder from toilet replaced wax ring dident
The wax ring would only help if the toilet wasn't sealed to the drain. Is the odor coming up through the toilet? If so then your water level must be low in the bowl, allowing the trap to be open to air. Make sure the little hose from the fill valve is dumping into the overflow. This helps make sure the toilet stays full, when refilling.
Posted on Jul 23, 2010
  • 24 Answers
SOURCE: The toilet tank doesn't fill
Kohler toliets can be a pain to repair. I have found with them that the only thing to do with them is go to a plumbing company, take the model number with you and replace all in the inner parts to it. You will replace the fill valve and flush valve. After I do this on Kohler I don't have anymore problems with them. It should work for you, just make sure they are Kohler parts. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
Posted on May 16, 2011
  • 12 Answers
SOURCE: toilet doesn't flush properly
First thing before you spend a bundle of money is to clean the ports under the rim and try flushing again.
Posted on Nov 06, 2011
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 | Plumbing
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Smell of sewer in the house
Ensure all your additional rough in plumbing is capped, and toilets or sinks that are not used for long periods of time , sometimes p traps may dry up allowing sewer gasses to enter the home so use them once in a while or fill with water once in a while ,same with floor drains. If that isn't it check that you have them installed.
Jan 06, 2014 | Northstar Sewer And Drain Cleaning...
RC 92+ Upflow Condensing Tappan Furance: we have sewer smell in basement that is strongest in furnace room. No floor drain. We have a pvc pipe with condensation hose from furnace in it. The trap continues...
the switch is a service or emergency switch if the condensation hose / line is not a sealed connection and the trap is empty the sewer smell will be constant either make it a sealed connection or close off the trap and reroute the condensation line --during heat season not condensation so heat will cause water in to evaporate
May 17, 2017 | Heating & Cooling
I being plagued with sewer gas how can i stop this
sewer gas is stopped by water in the drain. often three drain I. the floor dries out. or your drain is not holding water. pour water into all your drains. .
Nov 01, 2013 | Plumbing
Sewer smell in untility room that contains the air handler. A small pump recieves the condensation from the pan under the coils and pumps the water up where it connects with a drain line.
I would first check that you don't have a leak in you drain system, especially if it is very strong. If you can remove the pan easily (each installation is a little bit different so hard to to tell how hard it will be for you) and clean it thorought with soap and water.
If the pan can not be removed, then you might want to turn the pump and ac off for a time and pour bleach into the pan and let it set to kill the mold and germs in it. After the smell is gone, turn the pump and ac back on and then add a few drops of pine sol or other cleaner every week or so to keep the mold and mildew growth done.
Aug 29, 2011 | Ruud UBHC Air Conditioner
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
Jan 17, 2011 | GE Washing Machines
We live in a slab home. We have been noticing a order that smells like sewage. It is mainly coming from the floor heating vents in the kitchen and in the back laundry room. Is there a way to find out...
some where under your slab your sewer pipe has broken. most times you must cut away the concrete floor and explore for damaged pipes.
Jul 23, 2009 | Plumbing
Fowl smell in bathroom
Fowl smells related to plumbing can have several causes. Here's a few potential issues that you can check. If none of them solve the problem you may need to call a plumber.
1) Look at your pedestal sink drain connection. Is there an an elbow connecting to your drain or a P Trap? A p trap is a pipe shaped like the letter "p" (hence the name) and it prevents sewer gas from rising into the bathroom. **sometimes an apprentice plumber puts in a pedestal without a p trap because they are fairly difficult to install, and ALL fixtures need P traps. If there is no P trap, then you need to put one in. It will be a tight space, but you may be able to do it yourself.
2) Do you have a floor drain? If so, your sink will need a trap primer at the drain. Or you can pour water into the drain from time to time before it evaporates from the trap
3) If the smell is more of a sulfur type smell and it appears from running water in other places in the house, then it could also be due the type of tank you have if you are on well water
My offhand guess is that number 1 is your issue.
Without further info, those are some of my best solutions so far, but if none of these are potential solutions, then make the following tests
1) close the door to the bathroom and leave it for an hour or two. Return to the room. Do you smell sewer smell? Is it in the entire room or more concentrated in a certain area? If you don't have a floor drain and its everywhere, there could be a missing P trap from a fixture, a lose toilet flange, a cracked drain pipe
2) without running water, smell your drain. Does it have a sewer smell? Then the P trap either is not present or you need to clean the drain with a drain cleaner due to a list of reasons
3) run water. does the sewer smell increase or does one suddenly appear. Is the smell more a different odor than sewer. See if it is the water itself. If so, check other places. If they do not have the smell then you may have recently installed your sink and there is some smell related to the new valve. Then you would need to use it some more until it disappears.
Check the top list, though because I really think you're just missing a P trap
Sewer breaks below the slab, an open pipe somewhere, some issue with the water supply, are among some other issues but that depends on the test
Jun 22, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Fowl odor (sewer like) when washer is running.
Can you see the washer drain line,or is it inside the wall.
You should never smell sewer, I would find a good plumber,or a handy man that knows plumbing, and have him open the wall (if needed)
and install p-trap where the washer is located, at about floor level.
From what you said I think that someone ran a straight line to the cellar and installed the p-trap down there, also have them check the line to see if the line has been connected to a breather line, if not have him install a breather line right there with a one way breather valve inside the wall. The buildup and mildew around the compartment is due to the way it was made by the MFG of the machine, most 1000.00 front washers have a very poor design with this. All you can do is to remove it and clean it with bleach once a month. If you live in an nice area,but not very rich, the cost to do the drain should be around or under 350.00. I hope you get this squared away with no problems.
Mar 21, 2009 | Kenmore Washing Machines
Home Logo
379 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
