Question about LG WM2250CW 3.6 cu. ft. Front Load Washer With Dual LED
Lg wm2250c repair
Scraping sound between drum and heating element? how do i access unit
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Energuide rating for LG WM2250C*
97 kWh Estimated Yearly Electricity Use.
The link below is the Energy Guide from Home Depot's website.
LG WM2250C Energy Guide from HomeDepot
Hope that helps.
Sep 18, 2013 | Washing Machines
Indsit washingmachine: making scraping noise when spinning. metal drum inside feels loose and is leaning forward making it scrape on whatever is underneath. how do i stop the drum doing this?
If the inner drum is loose the bearing may have failed or the drum shaft spider may have broken. the scrapping will be the drum hitting the heating element.
Dec 30, 2012 | Washing Machines
Wire from wifes bra came out during wash and went through holes in drum on Daewoo Air Power DWD 1212S. Moving drum even by hand and the wire can be heard making scraping sound
If a front loader, put washer on a bench to allow proper viewing. If you cant apply tweezers to the b.c.spring from inside the drum, then you need to find the heating element. 90% of the time, the B.C.spring will be lodged against the element structure Remove element them carefully rotate the drum while looking inside the element hole. If you see it, devise a tool to remove it. Reassemble it and back to normal.
Sep 16, 2009 | Washing Machines
Blows main fuse under load when going to spin
Sounds like it's scraping against your heater element.Remove back panel then remove heater element(two prongs with nut in centre)you will be able to see signs of damage if so that will have to be replaced. £20 - £30.00p. Your either overloading your machine or your bearings are have gone, to check bearings pull inner drum while holding outer drum if get movement and knocking they will also need replacing.
May 19, 2009 | LG Washing Machines
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Hotpoint tumble dryer is making loud scraping noise like the drum is catching against one the panels
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Sep 10, 2008 | Dryers
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Drum won't spin freely
Are you sure that there is nothing sticking through the holes in the drum like a nail etc or a screw from trouser pockets, it could be that the heating element has come loose and is scraping against the drum or that the bearings have gone.
Feb 04, 2008 | LG WM-2077C Front Load Washer
LG WM1812CW noise
Other than seperating the drums you could try to remove the heater element which will allow you limited access to the cavity between the drums. Shine a torch in there and rotate the inner drum slowly untill the offending piece comes into view. Remove with a long tweesers or hook.
Oct 27, 2007 | LG WM1812C Front Load Washer
LG WM2250CW 3.6 cu. ft. Front Load Washer With Dual LED Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
