Question about Cub Cadet Garden
Cub cudet 31p7770299e1 briggs stratton engine
I HAVE A LT1018 CUB CUDET WITH A 31P7770299E1 BRIGGS STRATTON ENGINE , IT START AND RUN ,HAS ON POWER IDDLE OK AFTER 1/2 SPEED IT SPIT AND POP THRO CARBURETOR CAN'T RUN A FULL SPEED , CHECK KEY IN FLYWHEEL, CLEAN OUT GAS TANK AND LINES NEW FILTER , CLEAN CARBURETOR , REMOVE HEAD DID VALVE JOB AND RESET VALVES , REPLACE SPARKPLUG DIDN'T HELP STELL SPIT AND POP OUT OF CARBURETOR, ??? ON WHAT TO DO NEX,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Check and see if intake valve seat is loose as motor gets hotter condition worsens
Posted on Jun 07, 2014
ccrozier_agr
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
#1 Taper
  • 1041 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
SOURCE: Cleaned the Briggs & Stratton Riding Lawn
kehmahcliff:
It looks like that your valves need to be maintenanced. This can be done by small engine repair shops. They should have the proper tools.
Also the "timing" of the spark and the fuel injection could be a problem. I hope this helped you.
Greetings Joe
Posted on Sep 30, 2009
  • 18 Answers
SOURCE: I have a 4 hp Briggs and Stratton engine - stops running with gas
01 Sounds like you are describing the primer as being on the front of the carburetor air filter body. The line you describe is probably used to force air from the primer into the carburetor or into the fuel tank (a box of metal about 6" long by 3" wide by 3" deep?) on which the carburetor body mounts, from your description.
02 The engine will shut down with a little bit of fuel in the bottom of that tank. You should be able to remove the fuel cap, located on the top of the tank, just to the left of the carb and see into the tank. The carb does draw fuel from this tank as it runs.
03 How long does it run before quitting? If it runs ok and you get a small yard done and the engine does not emit black smoke, that might be normal.
Posted on Apr 19, 2010
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Cub cadet
It depends on what engine is on it... Briggs and Stratton or Kohler..usually Briggs are on the right side and Kohler are on the left
Apr 23, 2014 | Garden
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Looking to see if 12.5 HP briggs and stratton mount holes are the same as 16 HP briggs and stratton can these engeins be fitted across different lawn tractor platforms i.e will the Craftsman 12.5 B/S fit...
The bolt patterns are the same, space should not be a problem going from the OHV to the flat head. The only other thing you should do is physically measure both crankshaft extensions (the part that sticks out the bottom of the engine) making sure that they are the same length, diameter and bolt hole is the same.
The muffler might be a concern depending on how the Cub muffler was oriented.
As in any engine swap there may or may not be some modifications you have to do ie: throttle and choke arrangement, fuel line routing, alternator capacity and wiring etc. so I will say yes it SHOULD fit without modifying the tractor and/or frame and it can "be fitted across different lawn tractor platforms"
Jun 26, 2009 | Peg Perego Cub Cadet Tractor
Garden Logo
150 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
