Question about GE DPSR610EGWT Electric Dryer
Dryer will not start at all, It is Kenmore 110.96583820
I checked circuit in home, all good, Power cord is okay as well as the door switch. I am thinking it the thermal fuse but I cannot get to it. I cannot get the back off at all.( Seems to be riveted). How do I get to fuse to check it?
    Problem Solver:
  • 5 Answers
Wrong! On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Posted on Oct 14, 2009
    Genius:
  • 1,122 Answers
You have to go under the top,use a putty knife in the seam on the front top,there is a clip on each side,just pop them and the top comes off,look to the right side top beside the drum and you will see the little tiny main fuse,this is your problem,please leave me a nice fixya reply,thanks-mike
Posted on Mar 12, 2009
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
I have an electric Kenmore dryer that wont turn on
Apr 16, 2010 | Kenmore Dryers
Dryer won't turn on... start button "clicks" - but won't start
Make sure the power circuit is energized and the power cord is connected.
Most likely your start switch or door switch has failed. Other failures can also cause this symptom: bad thermal fuse, broken belt, bad timer, bad motor, etc.
Apr 09, 2010 | Kenmore 63942 Dryer
My kenmore 70 stop working wont enen start
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 11, 2009 | Kenmore 63942 Dryer
Won't start - 3 beeps when Start button pushed
CHECK THE FOLLOWING--
May 31, 2009 | Kenmore Dryers
Dryer will not start have replaced the heating element, door switch and on switch
hi, i recommend inspecting the terminal block that the power cord is connect to on the back side of the dryer. this terminal block may be faulty or, the cord could be lose and not connected properly.kindly, inspect this device that is located on the back side of the dryer for lose connections. if the termainakl block is in good conditon and, the power cord is screwed on tight, thsi iwll confirm timer fialuer.
replace the timer in this case.
May 20, 2009 | Kenmore Dryers
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
Dryer will not run
If the back of your dryer is solid your access is through the front.
Raise the lid, then remove the front panel.
Remember to unplu the dryer.
Mar 12, 2009 | Kenmore 62622 Electric Dryer
My Kenmore electric dryer won't start... I just ran it and it ran fine. Went to start a new load and it wouldn't work. Checked breaker, plug and door switch; everything seems okay
eazy first.need 220 if got,door switch it wiil click when depressed.next check where cord attaches.then the thermoal fuse.if has back panel or no same info.i call them missiles or flying saucers[thats what they look like].there white small have two wires to them.if you put the two wires too gether and isolate them,if problem your dryer will start,replace,but its a thermal fuse so the idea is if it gets to hot they open to stop fires,so mcheck all venting and dryer air waysGod is good,tom
Jan 02, 2009 | Dryers
Doesn't work at all
Check the door switch. With the door open, on the upper right side of the tub opening there should be a little lever. Push on it and you should hear a click sound. If the lever is broken or no click sound, you need to replace the switch. If that checks good check your circuit breakers and power cord and outlet.
Apr 08, 2008 | Kenmore 63032 Electric Dryer
GE DPSR610EGWT Electric Dryer Logo
134 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
