Question about LG LRE30451ST Electric Kitchen Range
Metallic mark in the burner area of my 1 month old LG -LR30453ST
The cook top is black, so this mark is very noticeable. Is this a manufacture defect or something that cooking may have caused? I have used a glass top cook top for 15 years and this has never happened before. Lg is telling me a service tech needs to come out to look at it, but will most likely determine it is a cosmectic blemish....Help please.
4 Suggested Answers
SOURCE: burner on range will not turn off
I am also having turn off problem on smaller burner of dual burner glass stove as of 8/2/08. It remains on high even when know is in off position.
Posted on Aug 03, 2008
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Posted on Nov 03, 2010
richroth
  • 9472 Answers
SOURCE: LG LRE30451 won't maintain temperature
Check the oven temperature probe (thermister) to see if it is good. To check it, use a multi-meter and Ohm it out. It should be between 1100 and 1600 Ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Posted on Nov 30, 2012
I had a 2inch by 2 inch black grease stain from a cast iron pot on my ceramic cook top. I used whirlpool cooktop cleaner and a razor blade to try to remove the black gunk. The more I used the cleaner and...
You could try a little oven cleaner on it. That should take care of the mark. After that, if it did not work, clean off the oven cleaner well and then try a bleach solution.
Post a comment with your progress.
Tim
May 03, 2009 | Kitchen Ranges
I have a Schott Ceran cook top that is marred with black stains all over the burners. The stove works, but looks awful. How much would it cost to replace top? The marks seem to be appearing from the bottom...
Use oven cleaner. Spray it and let it sit on a couple of hours. Scrape with a razor blade. It worked for me after trying everything recommened by the manufacture.
Feb 20, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
GE cooktop has porceline "popping" off literally.
Porceline (a coating over metal in this case) is actually a type of glass, and subject to fracture upon sudden thermal shock or physical stress. The part you indicate is WB62T10124 for a JGB939C1WW probably a bit over $150 or a WB62T10132 for a JGP939C2WW, probably a bit over $100, but the labor to replace it would be costly. If you rate this, please remember I did not manufacture this product, nor am I a GE employee, so please don't shoot the messenger.
Nov 28, 2008 | GE Profile JGP636 Gas Cooktop
Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Aug 22, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burner on range will not turn off
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
LG LRE30451ST Electric Kitchen Range Logo
77 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
