No compression
SOURCE: Cub Cadet 997 self propelled mower with 6.5
Might be just a loose head, Check that first, are the bolts tight? If loose I would clean head and install new head gasket and torque to specs. (In inch pounds).
SOURCE: i have a cub cadet push mower with a 173cc ohv
most likely a sheared flywheel key, pull the cover off the flywheel and remove the nut that holds the flywheel on. The key slot in the flywheel should line up with the key in the crankshaft if not pull the flywheel and install a new key, or take it to a small engine repair and they will do it for you. If the key is good, reassemble the flywheel nut etc and check for spark at the spark plug and see if the spark plug is wet with gas if you have spark and gas and the flywheel key not sheared and it still won't run, you may have an internal problem
i have a cub cadet 173 cc, mower,not starter,check the gas,oil,filter,blades all is good,but the electric stared not star,i need help.
