How to connect phono leads
Not sure which order the phono leads connect from the amp to the equaliser
  • Rommel Cana
    Rommel Cana May 11, 2010
    you need to connect it first to a phono preamp, without this you will not hear it well, before connecting it to equalizer.if your amplifier have phono input connect it there, have your equalizer out connected to tape in, equalizer in to tape out . hope this help.
    thanks for using fixya!
    Problem Solver:
  • 17 Answers
  1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
  2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
  3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
  4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
  5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
Posted on Aug 20, 2009
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
Technics SL-1210Mk2 Sound is very clear but low frequencies are very POOR.Other sources are checked i think the problem comes from the turntable. I replace my old phono pre amp with rolls VP29 and i check...
Possible that the negative feedback amplification is not compensating to the preamp.
The cartridges must match with the preamp so that the full frequency response is received.
If you can add along an equaliser to you phono path on way to the amplifier , the compensation can be set up to the room accoustics and taste.
Alteration of the input impedance to the amplifier with a network can also help but an equaliser might be tthe best for you
Sep 15, 2010 | Technics Audio Players & Recorders
Where do the cables go to hook up Beheringer EQ to2222mixer?
In the mixer there is an AUX with an input and output together. The output of teh equaliser must be connected to the input of the aux and the output must be given to the power amplifier. Make sure to keep the R&L channels in order from the source to the amplifier.
Adjust accordingly your equaliser to your requirement. Keep the bass and treble in your amp to mid position and boost only if required. Hope this helps you to connect. Good day
Jun 24, 2010 | Behringer Audio Players & Recorders
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Dec 30, 2008 | Spectrum Technical Hifi EQ-B5200...
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
Turntable setup into an hp 7590
In theory as long as you have a sound card installed, yes you can connect your turntable direct to your computer simply by connecting it to the audio input.
You will probably need a patch lead with twin line phono connectors on one end and a stereo 3.5mm jack plug on the other end.
Please note, the turntable or phono inputs on amplifiers are unlike all the other inputs, because they have a particular frequency response tailored for use with a headshell cartridge.
If you connect your turntable to an input that has not been tailored to the RIAA response curve, it will sound tinny. This is what probably happens when you connect to your computer. The input may also not be sensitive enough.
You may be able to adjust the frequency response if your sound card includes an equaliser. Alternatively, you may be able to download some audio software that will allow you to equalise your turntable.
All in all though, I'm sorry to say you would be better off with an outboard preamp.
Mar 08, 2008 | Technics SL-1200MK2 Turntable
How do I connect a turntable
I agree with 'radio head.'
Turntables require a particular frequency response and the input needs to be correctly equalised to accommodate this. If your amp had phono inputs these would be equalised internally.
Unfortunately, many modern amps no longer have phono inputs. There are two possibly three options.
1) You could obtain a turntable that includes built in Phono eq
2) As 'radio head' says, you can obtain in line active equalisers. These are called RIAA Equalisers (Equalizers if you're in the US) or RIAA preamps. This allows you to plug your turntable into a small box, then plug the box into one of the audio inputs on the back of your amp.
3) You may be able to adjust your mixer to the required frequency response and use it as a preamp.
What you cannot do, regrettably, is just plug your turntable into an ordinary audio input. It will not do any harm if you want to try it and it will make a noise, but you won't like it!
Feb 04, 2008 | Harman Kardon AVR 100
HELP installing kenwood KGC 9044
You will only use the front pre outs from the deck to plug into the only available input on the EQ. You will loose fading and subwoofer controls from the deck which is the main problem when using an eq. Then go from the eq to each of the 3 corresponding amplifiers (front, rear, sub). You will then use the eq as your control for ading front to back and sub control. Im sure by now you have it figured out anyway but if you need help, let me know. Be sure to leave good feedback so and get paid!!!!$$$
Jul 25, 2007 | Kenwood KGC-9044 11-Band Car Equalizer
(How To?) installing kenwood KGC 9044
You'll have to use your choice of either the front outputs or rear outputs to plug into the eq. Most equalizers I've ever seen only accept 2 channels of input, then give anything from 2 to 6 channels of output, depending on the eq.
223 people viewed this question
 Grubhead
Grubhead
