Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
After moving frigde and freezer quit.
When plugged in lights come on and frig sounds like it kicks on then kicks off. shortly after moving fridge had a weird smell.
  • Anonymous Apr 19, 2009
    The frige hadn't been used in 6 months and we moved and plugged it in but it won't get cold.
  • kcredit Apr 19, 2009
    Where is the start rely located?
  • Frigidaire Master
  • 3,361 Answers
Your compressor start relay has become loose or possibly defective.
Push it back on for a good connection.
Watch it when you plug the fridge in.
If it sparks replace it.
Posted on Mar 12, 2009
Freezer works great, fridge does not cool at all. Any ideas?
Sounds like the blower that circulates air from the freezer to the frig has quit. If you are mechanically inclined, a self repair is possible. You need the owners manual or service manual to get a part number and an exploded view of the frig. pdf. versions are usually attainable from manufacturer websites.
Aug 26, 2015 | Refrigerators
Maytag MSD2732GRW ice maker quit.
Hi dsandcs, how many water supplies does your fridge have?
I mean if you look at its back can you see one or two plastic tubes? (that transport the water to the frigde)
Dec 31, 2007 | Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
Cleaned behind and under the frig and now it won't work
Don't know if this a solution or not. We must have moved something or jarred something when we vacuumed inside the back. After we moved it out again, took the grill off the bottom in the front, cleaned it and put it back on, everthing seemed to work OK. We went to work that morning and when I got home in the afternoon, the freezer and fridge were both working fine.
Dec 14, 2009 | Amana Refrigerators
nead to know more, the area between the frig and freezer has a heater in it to prevent moister can turn this off by turning on the energe saver you nead to take the kick plate off in the frount and bottom off frig.on the right you should see the condencer coil's, clean them.
Nov 22, 2009 | GE Monogram ZDI15C Automatic Icemaker
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Fridge and freezer stopped working
you need to unplug asap,your compressor is short cycling,go to the local appliance part store and ask for a 3in 1 starter,this will help you get it started again,the directions are on the starter,very easy,plug frig back in and listen for comp. restart,let me know how you do-mike
Oct 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge is not cold but the light will turn on...
Try to uplug it for a few minutes then plug back in. Let us know if the compressor and fan kick on then otherwise we'll have to give more advice on where to look, etc.
Dec 24, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
136 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
