Question about Garden
Makita rbl500 blower
Put carb kit in still bogs down when you give it gas
  • 7,482 Answers
Hi Billy
You still have debris in the circuits of the carb.
Posted on Apr 25, 2013
Testimonial: "took carb back off shot some carb cleaner in still bogs down if u open it wide open, give half gas till it builds up then open it all the way and it's ok."
chad7houston
  • 62 Answers
SOURCE: Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
  • 398 Answers
SOURCE: Homelite 26D leaf blower bogs down in Run position
check the air filter.
Posted on Mar 02, 2009
SOURCE: Engine cut out
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Posted on Sep 11, 2009
SOURCE: echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Posted on Sep 24, 2009
SOURCE: bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Posted on Jan 07, 2010
How do i adjust the carb on an echo blower
Not sure what carb you have..You should be able to see a spring loaded air/gas adjustment screw on the carb..once running turn clockwise until motor starts bogging down then the other way until it does the same..keep adjusting back and forth unti it runs smooth..
you may have another on the bottom of the carb bowel..do the same with it...if this doesn't work needs a rebuild kit..good luck..
Sep 27, 2014 | Echo Pb-403T Leaf Blowers
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Blower runs at idle then when you give it gas it bogs down until it shuts off
try to choke it part way and see if it still bogs down, if it does then check your exhaust screen, if partial choke helps it then check fuel lines for cracks, fuel filter for being dirty and also remember fresh gas too, if all else fails clean your carb out.
Nov 19, 2011 | Garden
Bogs down at full thouldel tryed to adjust carberator
Hi
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
I have a mikita leaf blower i have had right at a year and used only a few times, it starts and runs but as soon as you try to give it gas with choke on or off it will die. it runs fine with choke on or...
Try changing the gas. Pour old gas out and put new gas in. Make sure the fuel mixture is correct.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Nov 27, 2009 | Makita Garden
Carb troubles 83 suzuki 850.
ur bike is becoming oldschool by the second-bout time the carbs r taken down n put in solvent-rebilt kits abound in mags n online
Aug 29, 2009 | 1983 Suzuki GSX 750 ES
Stihl leaf blower motor dies when i try to give it full throttle
If the low and high speed screw are adjustable give them a try. Start with one turn on the low and two turns on the high speed. If these screws are fixed then you will probably have to put a carburetor kit in the carb. I hope this has been of some help. Donnyb60
Mar 18, 2009 | Garden
Garden Logo
312 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
