Question about HP Pavilion dv6000t Notebook
My HP Pavilion dv6000 keeps restarting with blank screen
My HP Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any HW failure. It's reseting each 13-15 seconds after turning on so I'm unable to do anything and it doesn't even beep when booting. I've tried to reset the memory as well. Note: I've had a similar problem before with gfx card and they had to replace my motherboard but since then it worked without any problems.
  • ivons1 Mar 12, 2009
    The screen remains black all the time and F8 doesn't work - the notebook will reset again. The question is, if it really is the GFX, why there are no warning beebs to detect a HW failure.
I have the same problem with my hp pavilion! ive tried everything and cant get anything to appear on the screen. Keeps rebooting every 15 sec or so. Did you ever find a solution to this?
Posted on Jun 09, 2010
  • Fixator2 Nov 14, 2010
    Try fn F10
  • bornfor Feb 03, 2011
    If you keep pressing the F12 key repeatedly after you turn on the power, it should bring you to a screen that will allow you to go into BIOS or select a boot device. Mine told me that it was trying to recover from standby and the battery was critically low. I got it to boot from there.
    New Friend:
Hey i same the same prob same model !! i reball g.p.u and north ic both of them and nothing the same again result ...next step i will replace the g.p.u if doesn't work goes to garbage !!!
Posted on Jan 29, 2013
  • georgis197
    georgis197 Jan 29, 2013
    hey i same the same prob same model !! i reball g.p.u and north ic both of them and nothing the same again result ...next step i will replace the g.p.u if doesn't work goes to garbage !!!
  • 66 Answers
It is normal for computers to reboot when there is a problem. Before Windows XP starts, Hit F8. It will bring you to a boot screen. You can disable the reboot or you can go into safe mode to search for the problem. It might just be your GFX again. I would look into it more if I were you.
Posted on Mar 12, 2009
  • Atticus30
    Atticus30 Mar 12, 2009
    If you cant even see the boot screen. Your physical screen might be bad.
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Apr 09, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Trying to get my hp pavilion dv6000 to come on.The blue lights come on,but screen is blank.then after about 10-15 seconds it restarts.I have tried to get to bios and can't.I have also took out the...
just turn on keep hitting the f9 key and let it run the hardware test and check if there is any hardware failure
-and then try f 8 while restart and then try last know good configuration
Reply
May 22, 2011 | HP Pavilion dv6000t Notebook
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My HP Pavilion dv6000 is giving me a long beep then 2 short beeps when i turn it on. I cleaned it out and it worked for a few minutes but when i restarted it the beeps returned
If your system board fixed but come trouble again.
Sometimes flex power cable problem too.
Check out internal your system.
or Mainboard problem. video chipset.
Oct 07, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp special editon dv6000 display wont load.
Not sure if this is whats up with your laptop but there is a recall on the dv6000. The following link has more details on whether your laptop is one of those affected.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01087277&product=1842155
Mar 19, 2009 | HP Pavilion dv6000z Notebook
My hp notebook pc keeps on shutting down every 10 minutes or so
Check out HP's web site regarding an Enhanced warranty program for specific laptops. My DV6113us had a problem with it restarting and it was one of the model numbers covered. Bad Motherboard....
Mar 14, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000t Notebook Logo
5,449 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
