Question about Measuring Tools & Sensors
Engine lopes - Measuring Tools & Sensors
    New Friend:
  • 171 Answers
Whether idle or high rpm it is a lean mixture
Posted on Jun 23, 2013
What is causing the engine on my 01 chevy cavalier to lope
Easiest possibility would be a clogged fuel filter. One time I had a car that was loping and it was just 2 broken engine mounts. But could be a sensor or a bad cylinder as well. Need someone to help you decide which one is the culprit.
Jan 26, 2015 | 2001 Chevrolet Cavalier
Engine lopes after it gets hot won't maintain full RPM
still something in that carb that needs to be cleaned out
Feb 08, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Engine lopes 21.5HP OHV Inteck Briggs&Stratton How do I correct this LOPING problem? If I disconnect any one of the two spark plugs while the engine is running it smooths out. I had removed both the Choke...
It sounds like a dirty carburetor. The carb needs to be removed and cleaned. The loping problem you speak of is a tell tale sign that something is partially blocking a jet or passage in your carb. If you are not sure of how to do it, bring it to a repair shop. To set choke cable, you want choke valve wide open when lever is pushed in and valve closed when lever is pulled/ There should be a screw you can loosen to move cable forward or backwards to adjust. Throttle cable should be snug at low idle when lever in bottom position. There should be a set screw for low idle already set if it hasn't been adjusted yet. Same process to adjust this cable, watch that throttle valve opens completely when throttle lever is all the way up. Good luck, hope this helped.
Sep 08, 2013 | Craftsman Garden
Why does engine lopes but will not turn over?
When last time you have done tune up,fuel filter,coils.check battery and connection.
Apr 05, 2013 | Mazda Cars & Trucks
Engine lopes at low acceleration
try pluging egr vacume hose fixed my problem also loped when going down road at steady speed. hope this helps
May 04, 2012 | 1995 GMC Sierra
My engine keeps shaking. The RPMs go up and down. Sometimes it even stalls.
ENGINE LOPING CAUSED BY.LEAKING BY VACUUM LEAKS AT THE INTAKE MANIFOLD.CHECK ALL BOLTS ON THE INTAKE MANIFOLD TO MAKE SURE THEY TIGHT.YOU COULD HAVE LEAKING EGR VALVE OR PLUGGED PVC VALVE.DO A COMPRESSION TEST TO CHECK FOR LEAKING HEAD GASKET.DO A FUEL PUMP TEST CHECK FUEL PRESSURE.IT SHOULD BE 35 - 45 PSI.IF FUEL FILTER HAS NOT BEEN REPLACED.REPLACE IT FIRST IF FUEL PRESSURE TO LOW.DIRTY FUEL INJECTORS WILL CAUSE LOPING.TIMING CHAIN WORN.IGNITION TIMING OFF AND WORN LEAKING VALVES.AND WORN CAMSHAFT LOBES.ALL ABOVE WILL CAUSE ENGINE LOPING OR SHAKING.
Jun 17, 2010 | 1998 Ford Explorer
Engine lopes whan accelerator is pushed,poor gas
WEAK FUEL PUMP OR STOP UP FUEL FILTER.RESTRICTED EXHAUST LIKE STOPPED UP MUFFLER OR CATALYTIC CONVERTER.LOW ENGINE COMPRESSION.VACUUM LEAKS IN THE INTAKE MANIFOLD.BAD PLUGS.WEAK SPARK OR IGNITION .
Jun 05, 2010 | Ford F-250 Cars & Trucks
Engine lopes at idle and check engine light on
In this case having the check-engine light is a good thing. Take the car to AutoZone and have them scan the computer for codes - they do it for free, whereas a shop will charge up to an hour's labor. Have them give you a printout of the codes, and post them here as a comment/reply. I can help you define them and see what needs to be done.
Dec 06, 2009 | Isuzu Rodeo Cars & Trucks
Loping engine
try cleaning your idle control valve, make sure you dont have any codes in your computer, if you do address those codesl
Feb 01, 2009 | 2001 Chevrolet Silverado
Measuring Tools & Sensors Logo
16 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
