Question about Candy Washing Machines
Cdw250 electrical part
Would like to replace the on off switch where can i ordered it?
    President:
  • Candy Master
  • 662 Answers
Just search for 'candy washer parts' on this this site.
Pl click if helped....
Posted on Apr 23, 2013
Change brake light switch
brake light switch should be under dash mounted in such a way as to be switched when pressing brake pedal in order to replace locate it and remove electrical connector carefully and remove the switch from holding tab and install new one and plug electrical connector back in and check operation
Aug 06, 2014 | 1993 Acura Vigor
Need a new on/off switch?
They wear out. I had that happend on an h1610 "Powerwasher" brand. I replaced it with a regular switch that I bought at the hardware store or try to order a replacement online. Switches must be protected from water.
Jun 02, 2014 | McCulloch FHH18A Electric Pressure Washer
Wed5100v wont run
First, check the door switch to see that it is working. With the door open, push the switch and see if the light goes out. If it doesn't, replace the switch. Here is that part to order.
If the switch is good, then you need to replace the thermal fuse. Here is that part to order.
Dec 05, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Mar 13, 2010 | 2000 Volkswagen Beetle
91 Honda Accord EX Ignition Switch Problems
It needs the electrical portion of the ignition switch(back half).Remove lower knee dash cover,to expose back of switch assy.it is held in by two screws,remove and replace electrical portion
Oct 14, 2009 | 1991 Honda Accord
Power switch broken
I have the exact same problem...Have you found a place to buy a switch for the AVH2? I'm a licensed electrical contractor and I can replace the switch myself as well...if I knew where to get a switch. Thanks.
Jun 25, 2009 | Vornado AVH2 Vortex Whole Room Portable...
Driver side window failed in down position
I had a similar problem with the electric mirror switch. I removed the two screws in the door hand hole and remove the plastic part containing the switches for the windows, mirrors, and door locks. Turn the piece over and remove the connecting electrical plugs. Find the electric windows part and remove the four brass screws. Next use a small screwdriver to remove the switch. Look for small screws in the switch and remove them remove the bottom of the switch and see if the contacts are clean (these can be cleaned with alcohol) then replace everything in the reverse order. This worked for me with the electric mirrors switch. Cost nothing except time.
Feb 07, 2009 | 2005 Chevrolet Colorado
Eratic front wiper motor on a 1996 A4
It is not very difficult to replace the wiper motor, but first you must diagnose this problem. In order to find out the cause of wipers stopping you can try follows:
1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!!
2. Disassemble the plastic covers from the bottom of the windscreen.
3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). If the electrical feeding is OK you must replace the motor - steps 5, 6, 7. If not you must check electrical connections, the control switch of wipers and electric cables.
4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers running at Audi.
5. For have enough space to manipulation the wiper motor together with their mechanism you must extract the plastic cover of the engine computer box, and extract also the box screws. Then you can move slowly the engine computer box, just for a few milimeters.
6. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation!
7. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor.
It is not very simply, but it works.
Refit in reverse order.
Success!
Nov 14, 2008 | 2004 Audi A4
Washing Machines Logo
32 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
