Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
KitchenAid Side by Side
The freezer is thawing out and the fridge side getting warmer. I hear it trying to engage, then after about 5 seconds when it would normally come to life and start making the typical refrigerator noise, instead I hear a "pop". It's almos like the noise a lightbulb makes when it blows out.
Everything seems to work fine. The lights come on, there is a bit of cold air coming out of the ice maker, but it's not enough to make a difference.
Anything I can try before having to call in service?
Thanks!
    Problem Solver:
  • 4 Answers
If you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Posted on Apr 15, 2009
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Freezer is not cooling and food has all thawed.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Thawing a frozen water line to ice maker on kitchenaid refrigerator
You have two choices. Either turn off the fridge and freezer for a few hours or use a hair blow dryer to thaw out the line. J.
Jul 02, 2010 | KitchenAid KSSS42QMB / KSSS42QMW Side by...
Freezer thawing
heatman101
May 25, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Fridge not cooling...freezer works fine.?
Have you checked the damper at the top left hand side, could be frozen - take it off thaw it out and replace. The freezing could have damaged the unit though.
Jul 19, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator not getting cold in Fridge side
No. check this post from right here.
http://www.fixya.com/support/t245665-samsung_rs2556_refrigerator_side_not
Question: was the fridge running when you went to pick it up ?
Was it already on ?
My thinking is that you have the ice build up problem too and that it never thawed. If you unplug it, thawing could take days. Seriously. If you take the inside panel off and get some heat on it
only an hour or so.
You have the exact same model I do, and it works good, just designed poorly. It needs a drain hole on that condensor.
And your fan probably is fine. Do not spend $500.
Apr 06, 2009 | Samsung RS2556 Side by Side Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
379 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
