Question about Infinity SW-12 Subwoofer
Infinity SW12 sub woofer duck call noise when turned on?
Infinity SW12 sub was shipped and damaged slightly. now 2-5 seconds after start up it makes duck call noise. It last one second. then works OK. Thanks, Tom A.
SOURCE: bypassing the 150 watt blown amp with passive crossover
3/4 update: i bypassed the 300w amp on my first ovtr3 with a cs3006 crossover i purchased on ebay. the input wires at the base of the speaker were connected to the input of the crossover, the bass output of the new crossover was connected to the yellow/yellow-black lf+/lf- wires that used to leave the old 300w amp. the high freq output of the new crossover was directly connected to the leads coming from the speaker's tweeter (running the midfreq outputs from the new crossover to the input of the speaker's old crossover is no good, since the midfreq output of the new crossover would rolloff and provide little high freq to the tweeter). The mid-freq output from the crossover was connected to the input of the old crossover that came with the speaker (alternatively, i could have wired the mid freq output from the new crossover directly to the midrange speakers, but i figured the old crossover might have had some characteristics that would have been helpful. the result is better than i hoped for! true, the bass is not quite as floor shaking as before (and you need an amp that can boost +5-+10db below 350Hz and rolloff the boost above 350Hz), but the end result is more than satisfying and gives these speakers new life. I am using a Sony receiver that puts out around 200W for the front speakers.
Posted on Mar 04, 2008
SOURCE: PS-12 subwoofer problem - Infinity Customer Support number?
Fixed the problem...I just purchased another one online (from a store that has a good return problem) and will return the one that doesn't work! Cheers! :)
Posted on Jun 27, 2008
SOURCE: Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Posted on Mar 23, 2009
  • 133 Answers
SOURCE: When I push my subwoofer cone its work and when i
Looks like a broken copper braid that links the speaker terminal to the cone (from there on it goes to the coil which is underneath the cone).
Check the speaker connection terminals (near the magnet), you will notice that each terminal has a copper braid wire going from that terminal to the speaker cone.
Inspect both braid wires carefully at each end (near the speaker terminal and near the speaker cone), there will either be some damage to the braid at one or more of these four locations or the braid could be actually broken at any of these spots.
The braid can actually be resoldered at the point where it's damaged or broken - this task will require good soldering skills, mainly because this kind of braid wires are difficuld to solder (they are a bit difficult to clean because of their structure and solder won't attach itself well to oxydized copper), but also because some speaker cones are made of plastic which may melt if you overheat it with a soldering iron.
Besides that, when resoldering is being done, only a very short portion of the braid should be wetted with solder because the solder point will become rigid when the solder cools down, and the braid needs to remain very flexible when the speaker operates (if it's too rigid or too short, damage to the speaker cone could occur or the braid could get broken again when the speaker will be playing at a loud volume).
Hope you can have it repaired, it can be done at home, but there are also speaker repair shops where you can get it done (i'm not sure about the prices though).
Anyway, the alternative is to replace the speaker itself.
regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
SOURCE: problem with tss 450/230 sub which just emmits a
I am having the exact same problem. Just started yesterday, did you find out what the problem was? Thanks.
Posted on Sep 12, 2010
Tip
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
on Jul 08, 2014 | Sony 182556522 1-825-565-22 SUB WOOFER...
I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Mar 17, 2014 | Audio Players & Recorders
Sub woofer, duck call noise at start up!
Contact the seller and the shipper and have it replaced. You wont be happy unless you do. You will always wonder about sound quality.
Apr 29, 2013 | Audio Players & Recorders
My sub woofer making noise like machine gun w out connect toamp
Disconnect the sub-woofer and see if the noise stops, if so the amplifier is OSCILLATING and so produces the noise.This can be related to fault with the pre-amp or audio processing section. Try and heat up the circuit using a hair dryer and if the fault clears then there are faulty electronic capacitors. If leak is seen then the pcb must be washed after the capacitor is replaced which can solve the issue.
Mar 12, 2012 | Infinity BU-120 Subwoofer
How do i get the best sound from my infinity 1250w subwoofers
Make sure the ohm's are the same on all your speakers and amp.
You amp watt should be equal or higher then your speakers total amps.
You base box should be completely air tight, and have about 1/2 of the box stuffed with cotton.
Make sure you use a good thick speaker cables to connect from the amp to the speakers.
and finally, make sure your trunk seals tight and wont rattle... cause nothing sounds worse then someone pulling next to you and all you hear is a buzzing sound from the trunk rattling... Also... sell the infinity's and get something like memphis, or panasonics. :P
Mar 09, 2010 | Infinity 1250w Car Subwoofer
I have an infinity sw12 that is for some reason making a high pitched noise and some cracking noises as well. It does seem to work otherwise. I get the same noise when the cable to the stereo is unplugged....
It could be an internal "cold solder joint" however, if your lucky, it may just be dust buildup on the control pods and switches. Radio Shack sells "Tuner Wash" which will clean potentiometers (volume controls) and other electrical contact points. It's an inexpensive "try". Pull the volume and crossover knobs and lightly spray down with the wash. Let it set 10-15 seconds then move the control pod back and forth. Turn it back on and see if it's better. Hope this helps
Jun 26, 2009 | Infinity SW-12 Subwoofer
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Infinity SW-12 Subwoofer Logo
87 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
