Question about Dogs
Clean a breadboard
Clean blAck stuff off wooden breadboard
  • 50 Answers
Bleach then soap then lots of rinsing and then dry,
Posted on May 30, 2017
Using the wand stuff shoots out of the vacuum?
Hi there! It sounds like you may have a clog in your vacuum. Try these steps.
1. Remove the hose from both ends.
2. Use a broom stick or something similar to loosen and remove any clogs from the hose.
3. Remove the hood or bottom plate to access the brush-roll.
4. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
5. Clean all filters as your manual suggests. Replace them if necessary.
Hope this was helpful!
Jul 20, 2014 | Hoover Vacuums
Filter in getting clogged with black stuff every 2 months what is wrong?
The filters need to be cleaned my unit tells me to clean the filters about every month and if I dont the unit shuts off to protect it the black stuff is mold which would mean the humidty is to high
Mar 10, 2014 | Aprilaire 600 Humidifier
Black marks on clothing
hi, i think you will find the bearing on the drum is about to fail, you need to replace it, hope this helps
Feb 10, 2009 | Washing Machines
Black color left in dryer, cant clean
As a mechanic, and based on knowing the drum is mostly stainless steel, my first inclination is to grab a can of carb cleaner from the auto shop and a few paper towels, and clean it up.. but I'm cautious with that stuff as it's very flammable... and I'm a guy.
My other thought would be to call or visit your local fabric store. Talk to someone who knows about fabric dyes and ask them what cleaner you could use. It'll likely be less.. barbaric than my fist thought.
IF you try my first thought, spray it on the rag and wipe the drum. don't spray that stuff into the drum.. it flows fast and will take hours to fully evaporate. and let the drum air out over night before using, just to be sure. Have exhaust fans or other ventilation going. Just to be safe too.
Jan 21, 2009 | Maytag HYE3658AY Electric Dryer
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
Nov 03, 2017 | Kenmore 43142 Front Load Washer
Kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
May 10, 2008 | Kenmore 70088 Air Conditioner
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Dogs Logo
696 people viewed this question
Top Dogs Experts
Ruth summersides
Thomas Perkins
Thomas Perkins
Are you a Dog Expert? Answer questions, earn points and help others
