Question about Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
On my Garmin StreetPilot, the battery was low but then in the middle of giving directions the screen just turned black and powered off. I thought the battery must have just been dead but when I plugged it in there was no "charging" signs on the screen and it still would not turn on.
  • amanda_enter Mar 12, 2009
    I was traveling down the interstate and the Garmin just shut off...I made sure it was connected good and that the plug in for the charger worked...I plugged in the charge cable and tried to turn it on and got nothing...
  • 31 Answers
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
My Garmin c340 has locked up while in middle of road trip. had this unit 5 yrs, no probs Til now. stopped at roadside park, came back it said recalulating, then screen showed calc at 100%, but unit is...
remove the battery directly from its back for 1 hour and then reinsert it and then try.its got hanged in the standby mode and needs to be reset.this will help. keep updated.
May 04, 2009 | Garmin StreetPilot c340 GPS Receiver
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Tip
Full Reset to original factory status May cure many problems
on Sep 21, 2007 | Garmin StreetPilot C330 GPS Receiver
How to reset the Garmin streetpilot III deluxe
DO NOT DO THE FOLLOWING unless you know why you are doing it. If you press and hold ROUTE when the unit is powered up, you do a master reset. This will clear all data and user variables. Unlike previous Garmin GPS receivers, this will NOT clear the temp compensation curves and non user data.
If the MENU key is pressed and held when the unit is turned ON, an undocumented test screen is activated which incidentally measures battery voltage, temperature and a few other things. Pressing QUIT (several times) from the test screen gives you a set of display test screens.
Mar 27, 2009 | Garmin Streetpilot III Deluxe GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin freezes
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Sometimes heat in a car if left in can cause sun to over heat LCD screen.
Sep 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
197 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
