Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
No oil to chain
Is there a tube that delivers oil to the chain if s0 were is it located
  • Husqvarna Master
  • 7,482 Answers
Hi erick
Go to the following webpage and get the info you need
Bud
Posted on Apr 23, 2013
No oil being delivered to chain, oil hole is clear
is it oiling without the bar and chain on.? could be a blocked pump
Mar 09, 2016 | Makita UC3530A 14" Electric Chain Saw
Where does the impulse line go to from the engine block.?
There are two "impulse line(s)" on a typical "2 stroke chain saw.
One goes from the intake or crank case to the carburetor to drive the diaphragm "pump". Sometimes this "line" is built into the intake or transfer port and back to the carb by passage ways drilled into each and mating thru the gasket. The pressure pulses drive the "pumper carb" to deliver the gas, whether the upside down, sideways or vertical.
The other impulse line will go from the intake or crank case (between the carb and crank case) to the chain oil reservoir to lube the chain.
The pressure pulses (pos or neg) will drive the very simple oil pump to lube the chain thru passageways and/or tubes between the "bar oil" tank and the engine case where the chain bar is clamped to the engine. There are crossing slots in the case and bar that allow oil to flow and the bar to be adjusted in/out to tighten the chain. An internal passageway in the bar from the crossing slot to the chain groove gets the oil to the chain. Always be sure to clean these passages with a copper wire periodically as they tend to get clogged with very fine wood shavings.
May 10, 2014 | Poulan Garden
Help! carburetor pulse oiler on homelite xl chainsaw ut-10694-a
there is a breather hole somewhere you need to clean it up so you can find it probly on the cap
Mar 29, 2014 | Garden
How do i change the oil pump in a 2000 dodge intrepid
I'm assuming that you are talking about 2.7L, the check this procedure...
Removal & Installation - 2.7L Engines
  1. Drain the engine oil.
  2. Remove or disconnect the following:
    Crankshaft damper Timing chain cover Timing chain Crankshaft sprocket Oil pan Oil pickup tube and O-RING Oil pump
To install:
Fig. Oil pump mounting bolt locations-2.7L engine
  1. Fill the oil pump rotor cavity with clean engine oil.
  2. Carefully, install the oil pump over the crankshaft and into position.
  3. Install the oil pump mounting bolts and torque to 21 ft. lbs. (28 Nm).
  4. Lubricate the new pickup tube O-ring with clean engine oil and torque the pickup tube mounting bolts to 21 ft. lbs. (28 Nm).
  5. Install or connect the following:
    Oil pan Crankshaft sprocket Timing chain Timing chain cover Crankshaft damper
  6. Fill the engine with clean engine oil.
  7. Start the vehicle, check for leaks and repair if necessary.
Hope helps (remember to rate this).
Oct 02, 2010 | 1999 Dodge Intrepid
Need to change timing chain. do i need to remove the head?
Check the vehicle manual for recommended mileage for replacing the timing chain.Locate the timing chain,you will need to replace it if the automatic chain adjuster "also known as the tensioner " is damage or worn.Drain the cooling system and disengage the negative battery cable.Undo the spark plug wires and set the No.1 piston at Top Dead Center ( TDC ) of the compression stroke. Disconnect the engine undercover,vacuum and fuel hoses,harness and connectors,drive belts, power steering reservoir,alternator and bracelet,upper radiator hose and,air doct,front exhaust tube,intake manifold collector supports,collector and exhaust manifold and distributor.Prop up the oil can and take out the front engine mounting,the valve cover and camshaft sprockets,cam bearing caps and camshafts,cylinder head bolts, cam sprocket cover,upper chain tensioner,chain guide and the chain,idler sprocket bolt,cylinder head,intake manifold and cylinder head gasket and the steel oil pan. Place a steel cutter between the steel and aluminum oil pans.Slip the cutter around the the edge of the oil pan and disengage the steel oil pan,baffle plate,oil strainer and front tube. Secure the vehicle on jack stands and place a seal cutter between the oil pan and the cylinder block,slip the cutter around the edge of the oil pan.
Aug 15, 2010 | 1997 Nissan Pickup
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have poulan micro xxv chain not being oil when
wow thats an oldie, That saw uses a diaphragm pump located just above and in front of the clutch drum. Its going tobe hard to find one if its bad, Try cleaning out the oiler hole in the bar first, Then try running the saw without the bar and chain on and see if it pumps.Also check the oil pickup tube in the tank, It has a small screen on the end of it thats prone to sawdust clogging it. If it still does not oil then I suggest you locate the gasket and diaphragm for the pump before you take it apart. Remember to clean everything before reassembling,, Good luck
Dec 15, 2009 | Poulan Garden
Oiler thus not deliver oil to the chain
Take the chain and bar off and run a small drill by hand into the hole where oil comes out. If it is not blocked you can "stretch" the hole a little bigger and hopefully resolve this.
Mar 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
26 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
