Question about Acme 5001 Supreme Juicerator Juice Extractor
Lid wont come off - Acme 5001 Supreme Juicerator Juice Extractor
Same problem; looking for solution
Posted on Jun 03, 2013
We're can I get a replacement lid for my Bella Sendio juice extractor model 13694a
Fixya does not sell replacement lids and cannot advise sources.
Aug 05, 2017 | Juicers
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
The plunger to my Jack Lalanne juicer is stuck making it impossible to continue juicing. Nothing is blocking the blade or other parts. Can you help? Carol
this happens to me a lot. Take the lid off the juicer and turn the lid upside down take a hammer preferably a rubber mallet one and gently tap the bottom of the plunger while holding it upside down with bottom part of plunger up to your vision field tape it on bottom while trying to turn it into the right position (flat side to flat side) from the top putting a little torque on it..when it is tapped with a hammer or some similar tool far enough up the tube in reverse, it will then turn into the right spot if you tap the bottom with one hand while turning t to the right position on the top of the plunger and will be able to be removed but do not tap hard enough to break it.
Jan 17, 2011 | Jack Lalanne Power Juicer 250 Watts
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
I have a Krups Vitamight model 294 juice extractor. My son used it and now I can't get the pulp container off. I have never used it and the the manual is gone.
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
Nov 20, 2009 | Krups Juice Extractor
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
Having trouble getting lid to lock into place
I just got one of these from my dad and last night I proceded o clean it.I took all three of the loose parts off and they are now soaking.
But the middle base part took a little figuring out.
This morning I finally got it.
The center part that you are referring to locks down tight I am assuming so there are no leaks.
What I found to do was that when putting the base back in I had to posistion the spout to the left as far over as I could get it and push down hard. Once it was flesh with the unit while still pushing it, I then turned it to lock it in place.
Hope this helps.
Apr 25, 2009 | Kenmore JEX328S Juicer
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
116 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
