Question about Acme Juicers
Lid won't come off - Acme Juicers
We're can I get a replacement lid for my Bella Sendio juice extractor model 13694a
Fixya does not sell replacement lids and cannot advise sources.
Aug 05, 2017 | Juicers
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
Why won't my Jack La lanne's come on and it's new never been on
If there is not a flaw in the product itself it could be a problem with assembly or that the locking bar is not locked in place properly. The juicer will not operate if the locking bar does not click in to place in to the grooves on both sides of the lid.
Jack LaLanne has several HowTo videos posted that would be worth reviewing:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
You are also able to download a manual which includes illustrated assembly and disassembly instructions:
http://www.powerjuicer.com/power-juicer-manuals.php
If you are unable to lock the locking bar in place it suggests that some other component has not been installed in the correct position. Review the assembly instructions to make sure all pieces are properly positioned.
Thank you for using FixYa!
Oct 15, 2011 | Jack Lalanne Power Juicer 250 Watts
My machine won't turn on when I flip the switch. It is properly connected, I tried it in several outlets - that are working for other appliances and I am left baffled. I haven't used it in about 6...
do you have user's manual with wiring diagram? if not try H.B. If you get one, there is a diode that keeps your machine from frying from over-voltage. Kinda like a fuse, but is not a fuse. If you can check voltage across it, it is not the diode. That is a simple start and the most common problem for not starting.
Aug 03, 2011 | Hamilton Beach 67601 Juicer
I was just given a juicer and on the left hand side there is the know for turning on and off. I try to turn it and it will not budge, therefore I cannot juice anything. Is there a reason for this??
The metal handlebar needs to be snapped up into position on top of the juicer beside the feeding chute before the button will turn. It's a safety feature. The clear plastic lid goes on over it.
Hope this helps!
Jul 28, 2011 | Krups FSC111-70 300 Watts Juicer
Model 6001, when I used it to make orange juice, it shook so much the top lid became loose. Why?
Not designed to juice oranges, but if you must, feed it real slow. Your juicer went out of
balance that's why the extreme vibration.
Apr 04, 2011 | Acme 6001 Juice Extractor
How to instal the arm on omega 1000 juicer
Best way to do it is remove the four screws on the bottom to separate the base
and work from the inside. Sometimes the newer latch arms are not an exact fit
and you may have to do a little filing here and there especially if it's a tight fit over
the lid.
Feb 20, 2011 | Omega 1000 Juice Extractor
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
29 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
