LG 32LC2D TV power/standby flashes red , sometimes goes off
LG 32LC2D LCD TV
The power/standby flashes red when TV is off and sometimes goes off completly. When the power/standby is off it's impossible to power on the TV unless the TV is unplugged a few times and the power/standby starts flashing again. The problem is getting worse.
Thank you
Michael
  • 2 more comments
  • mdrip Mar 15, 2009
    Need some idea which is the most likely to be causing the problem and which board. If I buy a service manual where would I look to make sure ??
    According to first reply - "Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board."
    I see the flashing red led even if remove all cables so that's not the problem. As I mentioned before sometimes the red led goes off and it's impossible to power on the system.
    Powering on and off many times brings the red led on eventually , it starts flashing and then the set can be powered on and runs just fine. The problem is only seen powering on.
    I notice that the pc board that has the red led mounted on is conneted directly into a main motherboard (?). Is the problem more likely to be the power board or the "Digital board". Is the "Digital board" the main board that the pc board with the red led plugs into ??
    Thank you
    Michael
    Hoping for a more detailed solution. The received comments so far don't really help me fix the problem. Is this a known problem ??? how can I narrow it down more ??
  • mdrip Mar 16, 2009
    Not really that helpful I'm afraid. I know it's tough to narrow down a problem like this but I expected more. At least if the problem had been seen before and what the solution was in that case. I won't be using this service again.
    "circuit board malfunctioning" isn't helpful. I'm disapointed that I spent money to be basically told there is a problem. I know that. What I really wanted to know is some more detailed ideas. The service manual that I also paid for is useless as well.
    Sergeant:
    Champion:
  • 435 Answers
Since its working when you unplug and plug it again, the problem should be with a capacitor.
And it sounds like a problem in power unit. So, now you have to find out which capacitor has gone bad. You can physically see for any blown capacitors. if not, you can check with multimeters.
Posted on Mar 16, 2009
  • 6,784 Answers
Hi, this is an internal fault code that is being displayed by the lights in front or this set. you will need to replace the power inverter board. it has failed. you can reach this board by removing the back panel and screws. its behind the lower shield. just remove a few screws and clips and replace.
  • Michael Masters
    Michael Masters Mar 16, 2009
    this inverter board is quite slender in build and most of them are green with microchips lined up in a row.
  • 15,935 Answers
Download a service manual, and troubleshoot. Thats all we can do from our end as well.
We are not aware of your skillset and what testing equipment you have.
There can be many issues in regard to a blinking display. From Bad solder joints on a power supply board (my suggestion since the problem is in the starting up of the tv) to failed FETs or diodes etc.
Thanks for using FixYa
  • 49 Answers
Unfortunetely this is a problem wit hthe circuit board malfunctioning. The only way to get it working 100% is to have a repair center service it, which is costly = /
  • Michael Mueller
    Michael Mueller Mar 16, 2009
    In this scenario, the only thing to do is get the problem narrowed down to the closest number of components so you won't have to pay a huge Diagnostics fee at the repair center. Unless you have a degree in Computer Engineering, or someone to walk you through 3+ hours of repair work, you will need to have someone locally fix it.
  • 10,515 Answers
Thank you for asking your question on Fixya.com. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. This model is known for having issues with their power supplies failing. These are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
If the issue still persists, call Technician.
Do rate this soultion as a way of appreciating me.
Thanks.
Thanks.
Posted on Mar 15, 2009
    Scholar:
  • 164 Answers
If you are looking for the user manual; you can download from this link:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
I hope this helps,
Thanks.
  • 19,396 Answers
The TV goes in protection mode because an internal fault had been detected, probably a bad power supply or convergence ICs going.
  • Ginko
    Ginko Mar 15, 2009
    When the power/standby flashes red ,
    that indicates a fault condition.
    The flashing light indicates a diagnostic state called protection.
    When the Monitor goes on protection there are only two possible causes.
    1The
    internal circuits are jammed because of electrostatic
    chargesaccumulating on capacitors, or because of a wrong voltage read
    by themain chip on your monitor controller board. this started the
    protectioncircuit.
    2 The protection circuit detected a wrong
    voltage or abroken contact, identified an internal fault and kicked in
    , startingthe flashing light.
    If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
    If you are in situation 2 , then there is an internal fault.
    Common faults
    Check also
    the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
    can get same flashing statebecause of the video cable.
    Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
    If under warranty contact the manufacturer ringing the number on the user manual
    If you want to repair at your own expenses, just locate any good qualified repairer.
  • Ginko
    Ginko Mar 15, 2009
    You get service manual here: https://www.completeservicemanuals.com/l...">LG - LCD Television - Complete Service Manuals
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I have an LG 17LX1R LCD TV/monitor that won't go on. The power light on the TV flashed red . . . but that's it.
My LG 17LX1R had a almost the same problem. Red standby went to green for 1-2 seconds then back to red standy. Turned out to be bad caps on the power supply board. Yours is definately going to need to be opened up. Not a generic fix. You gotta ask yourself if its worth fiixing a 6-7 year old LCD tv with limited LCD life. New ones can be had for about $130-150.
Nov 06, 2010 | LG 17LX1R 17 in. HD-Ready LCD Television
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
Mar 12, 2009 | LG 37LC7D 37 in. LCD HDTV
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it...
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Nov 19, 2008 | Sony KV-35S42 35" TV
LG LCD 37'' standby problem
if you want i will buy the tv from you
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
801 people viewed this question
Top Televison & Video Experts
Electro Med Services...
