Question about Skil F0123400AB Na 10" Table Saw, 15 Amps
Handle to raise and lower blade is stuck in the down position
Saw has been stored for some time
  • 2,176 Answers
What I do is use some penetrating oil on the mechanism that raises and lowers the saw unit. Usually you will have to raise if a little and then lower and keep doing over until it moves freely. If the unit is rusted you might have to wire brush a little. I dont know what brand or model we are talking about but this works on the DeWalt and Bosch saws that I repair.
Posted on Mar 12, 2009
Bought a MAC ALLISTER 210 COMPOUND MITRE SAW and its upright but it will not lower down,
Probably not, 2 possibilities, 1. there is a lock button that is supposed to be used to lock the saw in the down position, it probably got pushed when the saw was in the up position or 2. the blade guard got tightened by mistake. if it doesn't move freely you cannot lower the saw. Good luck hope this helps.
Jun 28, 2017 | Saws
I can't raise my table saw blade when I crank the handle
My DeWalt Table saw does this,and for me its cleaning with a air compressor and nozzle. I cand seem to prevent it though. I tried grease on time and it just plugged up faster. I want to try a gravite lube next. To me it seems to be a desiegn flaw and I just clean the spline thead shaft that lowers and raises the blade. So far I just settled into a maintance air spray and it seems to work well enough.
Apr 07, 2014 | Ryobi Bt3000 Bt3100 Dual Slot Miter Table
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
The blade won't up & down any more
The wheel that you turn has a long bolt which threads through a type of nut on the motor assembly. You will need to turn the table saw upside down to check it. It maybe broken or jammed, There also could be a piece of wood the fell in there and is jamming the mechanisim.
Pleas leave a comment if this helped you out
Good Luck
Dec 20, 2010 | Saws
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
HOw to lift the saw in the up position
i have a bosch   it has a little knob on the side that i pull and give a half twist and release   then the arm will raise and fall until time to store it again
Nov 07, 2009 | Makita Tools 12" Compound Miter Saw -...
Has become difficult to raise & lower blade
I have a similar saw and love it. I saturated the gear with silicon spray and worked it a bit. This seened to do the trick.
May 07, 2009 | Saws
Mower deck is stuck in down (mowing) position
Hve you tried a "rust remover spray such as wd40,spray and lighty tap until operational. Please rate jj505
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
It's extremely hard to turn the handle to raise the blade. Lowering the blade is smooth and easy, but I have to apply an excess amount of pressure to turn the handle when I want to raise the blade.
If this is a new saw, return it to the store for an exchange, but if it's an older than a few months:
These contractor saws often acquire this problem. It's usually dust, specifically pine dust (it has sap thus making it stickier), on the screw or the sliding mechanism. What I do is:
  1. Unplug the saw
  2. Remove the blade
  3. Dismount the saw from its stand
  4. Lower the mechanism all the way
  5. Flip the saw over onto its table
  6. Access the screw and the lift mechanism
  7. Use a brush to remove the accumulated wood dust from the screw and the mechanism.
  8. If you have a leaf blower or access to one; blow the interior of the saw (wear eye protection always!)
  9. Do NOT oil the mechanism, this will only serve to gum everything up faster - use a dry lubricant (graphite or silicone) or none at all.
To avoid this in the future;
  1. Avoid resinous woods (not a likely solution).
  2. Blow the dust from the saw interior when finished using it (this works well) - use an air hose or a leaf blower, the leaf blower actually works best.
  3. After cutting and before stowing the saw; run the blade to its highest position and then down below the table. This pushes any dust off the mechanism and screw.
If you find little or no dust accumulation, it's possible the saw has a bent screw or binding mechanism and will require service.
Always be safe; unplug the saw and remove the blade when working on it, and always retract the blade below the table when not in use to prevent damage to the blade - or being cut by an exposed blade; they're sharp!
Mar 15, 2009 | Bosch 4000 - 07 Electric Table Saws
Skil F0123400AB Na 10" Table Saw, 15 Amps Logo
242 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
