The sound only works with the headphones and sometimes when I plug in a power charger. On rare occasions, it will start working for a little while but then stop again. SIRI sounds works. Alarm sound works. Speaker sound does not work when watching videos, listening to podcasts, music, etc.
SOURCE: iphone 3g has lost sound, mic, home button and charger port broke
check if any flex strip are hanging loose. and push them in their respective slots.
Testimonial: "thank you. im a noviceat this. if any has come out are they simple to put back in?"
SOURCE: iphone external sound
You need to clean the heaphones entry. cut the head of a ear cleaner so it's the size of the hole, with a little cotton left. Dump it in little alcohol and use it clean inside the hole. worked for me like magic.
SOURCE: everything on my 3G iphone works except the phone will not work
try restoring the phone in itunes.
SOURCE: iphone sound not working?
the iphone thinks it is still docked. Turn off the phone, then turn it back on and it should clear it. if not try restoring the phone in itunes.
This problem should not continue once restored, and if it does then see the people over at an apple store so they can make sure your phone is ok. They might even replace it for free.
