Question about Juicers
How to assemble?? - Juicers
Why won't my Jack La lanne's come on and it's new never been on
If there is not a flaw in the product itself it could be a problem with assembly or that the locking bar is not locked in place properly. The juicer will not operate if the locking bar does not click in to place in to the grooves on both sides of the lid.
Jack LaLanne has several HowTo videos posted that would be worth reviewing:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
You are also able to download a manual which includes illustrated assembly and disassembly instructions:
http://www.powerjuicer.com/power-juicer-manuals.php
If you are unable to lock the locking bar in place it suggests that some other component has not been installed in the correct position. Review the assembly instructions to make sure all pieces are properly positioned.
Thank you for using FixYa!
Oct 15, 2011 | Jack Lalanne Power Juicer 250 Watts
I am taking my juicer apart. I took the three screws out and the grinder plate. How do I get the filter out that is beneath the grinder plate.
Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
Mar 03, 2011 | Jack Lalanne Power Juicer 250 Watts
Anyone have the assembly guid? i fixed the switch
Hello did you find out were the springs go i have the same problem
Feb 20, 2010 | Braun MP-80 240 Watts Juicer
I have a Jack la lane power juicer and the power switch did not work. So I dis-assembled the motor and power switch and found 2 springs. Now I want to assemble it back but did not know where these 2...
The stainles bar has 2 springs on each end. Maybe this is the springs that you have. It is a power safety switch wherein there is no power if the bar is not seated in the right place.
Jul 06, 2009 | Jack Lalanne Power Juicer 250 Watts
I have a Jack Lalanne Power Juicer. The top piece
I am also looking for the same part. I have been unsucessful so far.
May 07, 2009 | Jack Lalanne Power Juicer 250 Watts
No manual, how disassemble for cleaning;miss platform/extra blade
I just posted this info on an earlier question.
Here's the link to the owner's manual (PDF) you can save or print.
http://www.powerjuicer.com/pdf/express.pdf
FROM THE TABLE OF CONTENTS
Important Safety Information
Helpful Hints
Parts List
Assembly
Disassembly
Cleaning Your Juicer
Troubleshooting
Jan 20, 2009 | Jack Lalanne Power Juicer 250 Watts
Will not start
Junk it and buy an Omega, they at least have a decent circuit breaker. Mine quit after starting it and the breaker won't reset. Fixed it with a car fuse.
Jul 14, 2008 | Juicers
Beaumark juice extractor not working when i assembled it?
Yu have to have the juicer on and properly postioned, it has a little magnet that activates the machine, if it is not on it will not turn on.
Mar 25, 2008 | Champion G5NG853S Household Juice...
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Juicers Logo
22 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
