Question about Photography
Not turning on
Is not turning on . New battery are installed
    New Friend:
    Problem Solver:
  • 12 Answers
Are the batteries in backwards check to insure the + matches the + on the battery. I have also had new batteries that were dead for some reason, help for Olympus can be found at http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1268
Posted on Oct 04, 2013
  • Dave Larson Aug 15, 2014
    When you got the new batteries did you charge them first? Look in the slot where the batteries go. The contacts should be shiny copper color. If not use pencil eraser and very gently scrub the contacts bit the + and the - if it uses A batteries
I have installed a new battery. impeller shaft is removed. I have removed the spark plugs. The engine turns over really good. With the plugs installed the engine struggles to turn over.
As you say 'impeller', I reckon this is a boat engine? Number one tip,
Year, make model horsepower
It is normal for the engine to turn slower with plugs in as you have the compression of air in the cylinders with the plugs in. Having said that, it should still turn fast. It may be the starter is losing power or the connections between the battery and the starter are corroded or dirty. One final thing is that you should always charge a new battery on a battery charger before you install it. If the battery is not FULLY charged, it is almost impossible for it to get full using the engine. You are basically just topping up.
Mar 14, 2018 | Boating
Will not start
  • Mate have you checked the battery and cleaned all lead ends. Even a new battery is sometimes be defective, have you got a mate with another battery to install to test to see if it is battery!
  • I would try that first if bike runs with another battery then you will know. Cheers
Feb 09, 2014 | kawasaki VN 1500 Vulcan Classic...
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
Car turns over. Installed new battery. Starts
Check for:
1. if plugs spark, could be a dead puter. 2. if electric gas pump is working 3. If central alarm wont let car start
Nov 08, 2009 | Honda Accord Cars & Trucks
New battery, new starter just installed wont turn over.
turn on your headlights ,then turn key like your going to try and start the engine and see if the headlights dim dramatically, then you'll know if you have a good connection to starter from battery, then check chg on new battery
Sep 26, 2009 | 1989 Ford Escort
Camera wont turn on has new batterys
Take the batteries out. Install the batteries making sure they are inserted according to the camera diagram on the inside cover. Once the batteries have been installed correctly turn the camera on. If it does not turn on, check the ON/OFF Switch.
Mar 26, 2009 | Sanyo VPC-S880 Digital Camera
My Dimage X31 Camera does not turn on even with new batteries.
Make sure that you have them installed the correct way +/- and also check that the old batteries didn't leak and cause corrosion on the battery connection tabs.
Mar 09, 2009 | Konica Minolta DiMAGE X31 Digital Camera
Camera won't turn on
Are they of the correct type according to the manual If they are then contact Olympus Technical support.
Apr 19, 2007 | Olympus Camedia D-390 Digital Camera
Photography Logo
165 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
