Question about Kitchen Appliances - Others
Oster toaster heats only on one side in each slot.
  • Martin B
    Martin B May 11, 2010
    Please clarify what is an Oster toaster?
    Sergeant:
    Champion:
  • 234 Answers
I would say a wire is burn off or element is bad
Posted on Mar 13, 2009
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
Oster 6058 Toaster Oven heating elements are not working properly. Can parts be replaced?
You will be able to locate authorized parts and service centers by visiting http://www.oster.com
Regards.
Jun 17, 2011 | Oster 6058 Toaster Oven with Convection...
Our Oster toaster-oven (Model 6232) takes a long time to heat up. The heating elements are no longer bright red but rather heat up to a "dull" red. Might the problem be related to the thermostat...
You might try going to oster.com. After putting in your country, at the top of the page click on Customer Service and fill in where you live and you will get a list of service centers that you could check with. If you know what needs replaced and can do it yourself, then use this address to get parts. This will give you a list of sites that sell parts. Maybe just get both parts to see which it is.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 17, 2011 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Pop up feature does not work and toaster is only one month old
Don't even try adjust or open the unit. Call the dealer or take it back to him or you will invalidate your warranty and that is not worth it. Let the dealer worry about it.
Feb 26, 2011 | Oster 4-Slice Extra-Wide-Slot Toaster -...
When I plug in my Oster 6248 toaster oven, it flashes error
This is caused by a bad contact on the heat sensor located on the top inside the oven...now if i could juste find the replacement part...
Mar 14, 2010 | Oster Toaster Ovens
User Manual Oster-Toaster-Oven-Broiler-6233
If manufacturer site is of no help, check here, they have the Oster 6233 manual for download.
Aug 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Kitchen Appliances - Others Logo
87 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
