Question about True GDM-12 Refrigerator Commercial
TRUE REFRIGERADOR MODEL-26 I LOOK FOR A LIMIT SWITCH
THE LIMIT SWITCH IT IS BAD ,WHERE I CAN BUY IT?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Which limit switch are you referring to. I can supply you with the part if you can give me a better explanation of what you're looking for.
Posted on Oct 29, 2013
I have space for a 64in.height,32 in. width,26 in. depth refrigerator. What size in cubic feet should I get?
Well, these measurements will limit the outside of the cabinet. The size of fridges almost always refers to the inside capacity. The relationship between the two varies a little from model to model. For instance if you get one with an ice maker, the inside capacity is less, but the outside is the same as the same fridge without ice.
You could buy for instance a Whirlpool 14 cu ft top mount freezer model, which is 63" h x 28" w x 26" d. The 18 cu ft is too big. Another possibility is the Frigidaire 14 cu ft.
Nov 13, 2015 | Refrigerators
Walter with bad semelhante in the back of refrigerador
Cooling is proper. If cooling is proper then drain line to be cleaned.
Dec 15, 2013 | Sharp Sj-K70mk2-Sl Top Mount Refrigerator...
P1030 fault code on 2004 Honda accord
did you google that?
P1030 (p1 is factory code not a generic fed code)
P1030 Honda Intake Manifold Air Control Valve Position Sensor Lower Limit Not ReachedSorry for caps. but this is the html code off the scan pages.
open the FSM it answers the reasons and tests. to do.
do you only want wild guessing? we can do that. sure.
here is 1 wild guess.
you have intake air leaks.
or the valve is bad
or the switch is bad.
id not throw expensive parts. id do the steps.
see alldata.com for the 1030 page and the steps.
or go to handa and buy the FSM.
or join a true honda forum.
Oct 19, 2013 | 2004 Honda Accord
I have a True GDM-26, that I determined had a bad temp control. I ordered a new control from a company the referenced the part number by unit model number. I did not take the original control to match. ...
the temperature control you need is a part# 800386. the one you got(800393) is a temperature control for a 230 volt cooler not 115 volt. it is a 230 volt control
Aug 06, 2011 | True GDM-26 Refrigerator
I have a side by side refrigerator and the fan is not working. I need one unit of a part numbered 3110109W used on Model number 02652DBA - SS65-2 - COMPARTIMENTO REFRIGERADOR or Model number 02582DBA -...
Ray -
I found this part on this site. Line # 25 reveals it to be a 127VvEvaporator Fan. Line 26 shows the same fan but operating at 220 volts, so choose wisely!
The site is Portuguese, so I assume it is in Brazil or somewhere else in South America and should be able to ship cheaper than from the US.
Good luck! Please rate my reply - Thanks!
Jan 10, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Slide out will not slide it is out but will not slide in, Battery is fully charge & electric is on. Any suggestions? 1998 Fleetwood Mallard 26' travel trailer
GO TO THE ELECTRICAL PANEL WHERE THE CIRCUIT BREAKERS ARE,ON MOST MODELS, THE DC INVERTER (12VOLT) IS BUILT TO THE AC (120 VOLT)BREAKER BOX.CHECK THE FUSES ON THE DC INVERTER SIDE(SHOULD LOOK LIKE AUTOMOTIVE FUSES) IF FUSES ARE GOOD,CHECK FOR PROBLEMS AT THE TRAVEL LIMIT SWITCH LOCATED SOMEWHERE AROUND THE TRACKS THAT THE SLIDE TRAVELS ON.SOMETIMES AFTER SITTING FOR A WHILE THE LIMIT SWITCH DO NOT MAKE PROPER CONTACT FROM AGE,USAGE, CORROSION,ECT.,EASY THING TO TRY IS MANUALLY MOVE THE ACTUATOR ON THE LIMIT SWITCH SEVERAL TIMES WITH YOUR HAND ,YOU SHOULD FEEL OR HEAR IT CLICK. THOUGH IT IS SELDOM THAT THE LIMIT SWITCH IS A PROBLEM,IF THE FUSES ARE ALL GOOD,THE ONLY THING LEFT IS THE SLIDE MOTOR WHICH CAN BE LOCATED UNDER THE TRAILER AROUND THE SLIDE TRACKS,UNPLUG THE WIRES,HAVE SOMEONE PUSH THE SWITCH WHILE SOMEONE CHECKS FOR VOLTAGE AT THE MOTOR,YOU SHOULD USE A TEST METER ABLE TO READ AND VERIFY 12 VOLTS DC.IF YOU HAVE 12 VOLTS DC WHEN BUTTON IS PUSHED,MOTOR MAY BE BAD,PLUG WIRES BACK TOGETHER,MOVE TO A SAFE PLACE AWAY FROM POTENTIAL PINCH POINTS AND PUSH THE BUTTON AGAIN.
THERE MAY BE A CHANCE OF BAD CONNECTION AT THE MOTOR PLUG.
I HOPE THIS IS NOT TOO CONFUSING,AND THE PROBLEM IS ONLY A FUSE BECAUSE A FUSE IS A MUCH SIMPLER,CHEAPER FIX.
BEST OF LUCK.
Oct 30, 2010 | Electronics - Others
True model gdim-26. runs fine unitl defrost then does not keep cold after defrost.
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Mar 23, 2010 | True 26 cu. ft. Commercial Freezer GDIM-26
True GDM-12 Refrigerator Commercial Logo
59 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
