Question about Philips Televison & Video
Sony tv KDL40S20LI
"color" is all messed up. Doesn't show any red. Faces are all green.
  • 280 Answers
SOURCE: What is the best technic to adjust the colors on my TV
The easiest way is ... from the menu set all video to default. if there is nothing wrong with the set it should look normal.
Posted on May 23, 2008
SOURCE: SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Posted on Aug 05, 2008
phongnv
  • 56 Answers
SOURCE: My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Posted on Feb 18, 2009
  • 20 Answers
SOURCE: RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Posted on Sep 03, 2009
taran_2005
  • 10515 Answers
SOURCE: I have an LG plasma model# DU-42PY10X that seems
This is a common problem on these sets. As the menu is fine, this is highly suggestive of an internal failure.you have a driver board failing if you would open the set and on the left side is the Y-sustain board there are two boards connected to the Y SUS board. The one on the top drives the top half of the picture and the one on the bottom drives the lower half of the picture open the ribbon cables make sure to clean it or Re solder if you see needed turn set on and test, sometimes cleaning this will fix problem sometimes re soldering will fix problem and last resort is, the board itself is bad.Unfortunately,you need to diagnose and inspect all the components before replacing any part.If you wish to repair it yourself, i could give you a link to buy the service manual and would upload a troubleshooting chart ( generic ) that would explain how you need to diagnose the fault when you open the TV.However, there is no quick fix. It has to be opened and tested and then diagnosed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 18, 2011
Kp57hw40 is a greenish color
If green appears to bleed out of objects then it's probably the saturation level is to high. If that doesn't work you can try changing the Hue setting more towards red and away from green.
If neither works and you don't have a warranty I would call your a local TV repair company.
Oct 22, 2012 | Sony KP-57HW40 57" Rear Projection...
My tv only shows in green and purple
Have you examined the color wheel this set should have?
look for (remove lamp as it faces that) any segments broken or missing.
A color wheel also can have a high pitched or fan like sound but not always.
check the wheel first.
Jun 15, 2012 | Samsung HL-67A510 67" DLP HDTV
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Color alignment kpwt500 tv
i would have a shop reconverge it.thats going to be the easiest way to get the picture back the way it should be.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
TV coloring messed up
my sony did that but would turn off and not leave on. its not recommended to use like that (from tv repair man). theres a chip inside the tv that blew. it cost me 260 bucks to get someone to come and fix it.
Nov 01, 2007 | Televison & Video
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
