Question about Spark SP1604 1-43 Matra Simca MS 120B No. 21 French GP 1971
14 hp Kawasaki
Hi there need Help bad I have a 14 HP Kawasaki John Deer Rider. I can be mowing and seams when It gets hot it will die and not start until it cools down, Now that mowing season is back it will not hit a lick, I changed coils, I have good spark though bye using a test light. But I plug in a new spark plug, I got no spark at all. I changed the plug 3 times hoping it was just a bad plug. I looked it up on you tube on the proper ways to test a coil and I did them all and everything checked out. But I cant get the plug to spark, and suggestions, is greatly appreciated.
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
My John deer start and then die replaced the fuel filter
There are not of reasons for lawn mover starting and then dying.
Please see this John Deer site for possible causes and fixes.
Sep 03, 2014 | Garden
Why is my John Deer la130 miss firing when i do anything with the tracter?
bad gas?
water in carb?
gas filter clogged?
air filter clogged?
Jul 31, 2014 | John Deere Garden
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
09 JD X 340 27hp Kawasaki eng\ surges
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Not getting fuel to filter on a john deer rider
there may rust in the fuel tank blocking the line.
Sep 07, 2009 | Garden
Spark SP1604 1-43 Matra Simca MS 120B No. 21 French GP 1971 Logo
48 people viewed this question
Top Spark Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Spark Toy Expert? Answer questions, earn points and help others
