Question about HP Computers & Internet
Screen has gone black.
I have power, am using a spare screen wit CPU.
Any suggestions on how to repair?
Thanks
  • ru48623451 Mar 12, 2009
    Thanks for the look see, but that's not an acceptable option.
    I know there's a fix out there.
  • 66 Answers
Usually when monitors go bad, its best not to mess with them.
Posted on Mar 12, 2009
  • Atticus30
    Atticus30 Mar 12, 2009
    what type of input is it?
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
Screen is black will not take pictures
If screen is black you have 2 situations: camera is power on or power off. If its power on and screen is black, its very possible to have something defective inside on the cam microcomputer board or with the display block, and my suggestion is to get to a repair shop for a test or if you are still in the grace period from the manufacturer, to ask for a free investigation. Cheers (PS sometimes black screen occurs when the LCD inverter is gone)
Dec 09, 2010 | Canon PowerShot A400 Digital Camera
Wii powers on. screen stays black.
check all the cables are in the right places and secure, if it still shows a black screen try it out on a differant tv to make sure its not a fault wit da tv your using
Jan 29, 2010 | Nintendo Wii Console
Blank screen (Black) on Acer Aspire 9100, 2005 version, Laptop
Because you have tried it on an external monitor tells me it's nothing to do with screen, inverter or backlight.
This because if it was any of the above you would still get a display on the external monitor.
It's either one of two things: faulty memory or its not seated properly. check on the system memory, clean the contacts and slots and make sure you seat it properly. if you have more than one stick of memory installed take one out and rotate them one at a time turning the laptop on in between.
If you still get nothing on screen then chances are that the GPU (graphics processing unit) is shot.
Good luck.
Dec 04, 2009 | Acer Computers & Internet
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Black screen when i turn my cpu on hp pavilion a520n
Well, in the second (Gege) case you have a bad windows. Repair using a recovery CD (one most likely came with your comp). Whyme, take it in for repair; someones been messing with your BIOS.
Feb 04, 2009 | HP Pavilion dv6000z Notebook
My screen has been going black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After went black, you have check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Mar 05, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
